P2 Director did not create features directory [message #126812] |
Mon, 02 March 2009 15:49  |
Building a product using PDE headless build, allowing PDE to generate p2
metadata and publish artifacts. The result of the pde build
generated/published p2 repo looks like:
dist/PDEOUT/p2
|-- artifacts.xml
|-- binary
| `-- com.myproduct.launcher.gtk.linux.x86_6.4.0.qualifier
|-- content.xml
|-- features
| |-- com.myproduct_6.4.0.902271038.jar
| |-- org.eclipse.cvs_1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7. jar
| |-- org.eclipse.draw2d_3.4.2.v20090218-1145-3317w311_122502441.j ar
org.eclipse.equinox.p2.user.ui_1.0.2.r34x_v20090120-7d-7tEQc CaaYSBeNOClOn02267.jar
| |-- org.eclipse.gef_3.4.2.v20090218-1145-67728084A56B4I233613552 .jar
org.eclipse.help_1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nO mbM9VK.jar
org.eclipse.jdt_3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO 4BbDI.jar
org.eclipse.platform_3.4.2.R342_v20090122-9I96EiWElHi8lheoJK JIvhM3JfVsYbRrgVIWL.jar
org.eclipse.rcp_3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHc YBr4A63.jar
`-- plugins
|-- com.ibm.icu_3.8.1.v20080530.jar
|-- com.jcraft.jsch_0.1.37.v200803061811.jar
|-- com.myproduct.plugin1_6.4.0.902271038.jar
(etc)
Then, the directory is executed like this:
/eclipse342/eclipse -debug -consoleLog -nosplash --launcher.suppressErrors
-application org.eclipse.equinox.p2.director.app.application
-metadataRepository file:dist/PDEOUT/p2 -artifactRepository
file:dist/PDEOUT/p2 -installIU com.myproduct -destination P2TARGET
-profile MyProductProfile -profileProperties
org.eclipse.update.install.features=true -bundlepool P2TARGET -p2.os linux
-p2.ws gtk -p2.arch x86 -roaming -flavor tooling -vmargs
-Declipse.p2.data.area=P2TARGET/p2
but the result is:
P2TARGET/
|-- artifacts.xml
|-- p2
| |-- org.eclipse.equinox.p2.core
| | `-- cache
| | |-- artifacts.xml
| | `-- content.xml
| |-- org.eclipse.equinox.p2.director
| | `-- rollback
| | `-- content.xml
| `-- org.eclipse.equinox.p2.engine
| `-- profileRegistry
| |-- SDKProfile.profile
| | `-- 1236026322392.profile
| `-- MyProductProfile.profile
| |-- 1236026321886.profile
| `-- 1236026339881.profile
`-- plugins
(etc)
Missing "features" ! (I eventually learnt, not by the docs nor the wiki,
that the executable, ini file, etc are all in the "binary" zip)
En passant -- I picked a "profile" name at random... is that right?
Thank you,
Eddie
SOLVED - Re: P2 Director did not create features directory [message #126865 is a reply to message #126827] |
Mon, 02 March 2009 18:22  |
Huh, solved (pending runtime testing)
The documentation (scattered around wikis, newsgroups, etc.) should be clear
on something: the IU for a product should be the product ID used in the
extension point... I kept using "com.myproduct", which matches the primary
feature name. The product ID is "com.myproduct.product" and using that as an
installIU produced the right thing -- dropins folder even!
- Eddie
"Eddie Galvez" <eddie@grassybrook.com> wrote in message
news:gohj3e$sj3$1@build.eclipse.org...
>I want to follow up that I tried running the metadata generator by hand
>based off of a non-p2 build output (what we have since we build our product
>against 3.3), ran the director... and ended up with no features again!
>(Note that the p2 repo created looks fine, features and plug-ins are
>present).
> - Eddie
FUDForum. Page generated in 0.04070 seconds
