Jar packager - adding META-INF with path munge [message #126677] |
Fri, 12 December 2003 11:33 |
Originally posted by: michael.erskine.jasmin.plc.uk
I was unable to find an answer in the archives for my problem: -
Our company is moving over to Eclipse for our Java IDE and we enjoy its
many features. We maintain a system that has many jars to deploy as EJBs,
services etc and each jar tends to have different META-INF content. I'd
like to tell the Jar packager to add various files to META-INF that don't
necessarily reside in the proj-root/META-INF dir. Is there some XML
attribute I can include in the jardesc to allow these files to gain the
correct path?
Michael.
Re: Jar packager - adding META-INF with path munge [message #127455 is a reply to message #126677] |
Mon, 15 December 2003 15:33 |
Originally posted by: daniel.megert.gmx.net
Michael wrote:
>Hi,
>correct path?
Not sure whether this helps: you can provide your own meta-inf file.
Dani
>Regards,
>Michael.
Re: Jar packager - adding META-INF with path munge [message #127802 is a reply to message #127455] |
Tue, 16 December 2003 08:52 |
> Dani
Thanks for your reply Dani, but my issue is that I need to supply a
_different_ META-INF dir for each of the 20 jars that need building and so
I need to be able to specify its location perhaps outside of the project
tree (but preferably inside).
Michael.
Re: Jar packager - adding META-INF with path munge [message #128207 is a reply to message #127826] |
Wed, 17 December 2003 16:08 |
> You probably want to use ant for this.
> Simon
Sigh! I feared as much! We use Ant 1.4 which doesn't properly pick up all
inner classes -- perhaps we need to move on!
FUDForum. Page generated in 0.03702 seconds
