Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling Tomcat Servlet - No Events
Profiling Tomcat Servlet - No Events [message #126670] |
Tue, 18 March 2008 00:51 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: thomast.hexi.com
This is my first attempt at using the TPTP profiler on a Tomcat Servlet launched through
webtools. I've been successful in profiling a java application. Here is what happens:
- I click the "Start server in profiling mode" button
- I get the "Profile on Server" Dialog.
- In the "Destination" Tab I browse for the project I want to profile for "Profiling project"
- Monitor: DefaultMonitor
- In the Monitor tab I select any of the JRE 1.5 or newer data collectors
- Click Finish
- The server starts up and after the init is run for the servlet, I see "connecting to
JVMTI agent" in the status. That goes away after a bit.
- I then see in the status: "Processed: xxxx bytes, bytes/second: xxx, events processed:
0, events/second: 0, elapsed time: xxxx seconds"
I never see any events and the views associated with the data collectors always say "No
data is available for display". I do see bytes being collected, though. Something is
talking.
Any hints on where the disconnect might be so that the data collectors will start collecting?
Note, I'm currently on jdk1.5.0_06 for the server.
-Tom
Re: Profiling Tomcat Servlet - No Events [message #126776 is a reply to message #126724] |
Tue, 18 March 2008 21:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello Eugene,
I'm afraid I'm not sure how to answer your questions. Where do I find "view filtering
support"?
The view (Object Allocations: Memory Analysis, in this case) says (Filter: Default
Filter). I tried modifying the "Default Filter" by editing the properties of the
"<monitoring> Profiling (...)" entry in the Profiling Monitor and adding an entry for our
packages (com.sersol.*). This had no effect. I still get "No data is available for display".
Other than that, I'm afraid I don't follow. Where is the "filter setup of the trace
configuration"?
Sorry for being dense and thanks for taking the time.
-Tom
Re: Profiling Tomcat Servlet - No Events [message #127079 is a reply to message #126670] |
Thu, 20 March 2008 17:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hey All,
I'm still struggling to figure out why I am not getting any data profiling a Tomcat
servlet launched through the webtools server launcher. Especially since I have no
problems getting data from a standard JUnit run on the same project. Any hints on where I
should be looking or documentation that would be relevant is welcome.
-Tom
on 3/17/2008 5:51 PM Tom Talbott said the following:
> launched through webtools. I've been successful in profiling a java
> - Click Finish
> "connecting to JVMTI agent" in the status. That goes away after a bit.
> events processed: 0, events/second: 0, elapsed time: xxxx seconds"
> always say "No data is available for display". I do see bytes being
> collected, though. Something is talking.
> -Tom
Re: Profiling Tomcat Servlet - No Events [message #127217 is a reply to message #127079] |
Fri, 21 March 2008 17:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
To follow-up, I was able to get data from a simpler webapp. There is one obvious
difference between the webapp I can profile and the one I can't: The init of the one that
is not getting data takes a while (couple of minutes). Other than that, they are
structured relatively the same. Is something timing out? Giving up?
-Tom
on 3/20/2008 10:09 AM Tom Talbott said the following:
> Hey All,
> profiling a Tomcat servlet launched through the webtools server
> launcher. Especially since I have no problems getting data from a
> standard JUnit run on the same project. Any hints on where I should be
> -Tom
>> Servlet launched through webtools. I've been successful in profiling
>> - Click Finish
>> see "connecting to JVMTI agent" in the status. That goes away after a
>> bit.
>> collectors always say "No data is available for display". I do see
>> bytes being collected, though. Something is talking.
>> Thanks,
>> -Tom
Re: Profiling Tomcat Servlet - No Events [message #127227 is a reply to message #127217] |
Fri, 21 March 2008 23:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Another follow-up: After continued fiddling, I am now getting data in my main project. No
idea what exactly got it going. The only real problem now is that it locks up after only
a few minutes. I've read elsewhere that this is can be a problem. Makes it hard to track
down slow memory leaks, since it won't stay up long enough to figure out what is going on.
I've tried increasing memory in eclipse and for the server. Seems to lockup before memory
is used up. It's definitely the VM that is locking up, eclipse keeps running. Any hints
on keeping the profiler from locking up a webapp that does lots of data processing?
Narrow down the amount of instrumentation?
Thanks in advance,
-Tom
on 3/21/2008 10:36 AM Tom Talbott said the following:
> one obvious difference between the webapp I can profile and the one I
> can't: The init of the one that is not getting data takes a while
> (couple of minutes). Other than that, they are structured relatively
> -Tom
>> Hey All,
>> Thanks,
>> -Tom
>>> collectors
>>> - Click Finish
>>> a bit.
>>> xxx, events processed: 0, events/second: 0, elapsed time: xxxx seconds"
>>> Thanks,
>>> -Tom
Re: Profiling Tomcat Servlet - No Events [message #127304 is a reply to message #127247] |
Tue, 25 March 2008 23:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Asaf,
Thanks for the reply. There is another way to limit the data being collected and that is
in the "Profile on Server" dialog. Select the "Java Profiling - xxx" category you are
going to use and click "Edit Options". You can create a filter set that limits what
classes to collect data on. This significantly reduced the number of bytes of data being
collected during runtime and has helped me get further along, but eventually the webapp
still locks up. The last time I ran it it stopped at:
Processed: 19074317 bytes, bytes/second: 2999, events processed: 175292, events/second:
27, elapsed time: 6359 seconds
I don't see any errors in the eclipse error log. Is there somewhere else I can look?
-Tom
on 3/24/2008 4:27 AM Asaf Yaffe said the following:
> Tom,
> Assuming your are using the Heap Profiler (i.e., the memory analysis
> data collector), your options of limiting instrumentation are quite
> limited at the moment. You can use the filtering capabilities (in the
> Monitor tab) to specify which types of allocated objects to track, but
> of-course this is useful only if you know upfront what are the types of
> the leaking objects. Another option is to limit the amount of the
> collected data by using the "pause collection" and "resume collections"
> actions in the Eclipse Profiling Monitor view.
> HTH,
> Asaf
Re: Profiling Tomcat Servlet - No Events [message #127452 is a reply to message #127403] |
Thu, 27 March 2008 23:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Asaf,
Just to clarify, when you say "collecting data into a file" are you referring to the
"Destination" tab in the "Profile on Server" dialog when launching Tomcat from within
Eclipse? Or, are you referring to running the profiling standalone (outside Eclipse)?
The only way I've found to get a thread dump running Tomcat from Eclipse is to use a
program like StackTrace to initiate a dump (Note, this is on Windows).
I have tried one run now with the "Send profiling data to a file" set and the Tomcat
process still locked up. Unfortunately, it locked up to the point that I was not able to
get StackTrace to dump the threads. I can try to set it up in standalone mode to see what
happens there, unless you have other suggestions.
-Tom
on 3/26/2008 11:51 PM Asaf Yaffe said the following:
> Tom,
> Did you try collecting data into a file (rather than sending data
> "online" to the workbench)? Does your application still locks-up in this
> case?
> If so, can you create a thread dump of the Tomcat server (usually by
> hitting Ctrl-Break at the console window running tomcat) and post it here?
> Asaf
Re: Profiling Tomcat Servlet - No Events [message #127568 is a reply to message #127452] |
Sat, 29 March 2008 00:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Follow up:
I ran tomcat using standalone profiling without any filtering file and it locked up within
about a minute of running my test case against the server:
Set TPTP_AC_HOME=C:\agntctrl.win_ia32-TPTP-4.4.1
Set JAVA_PROFILER_HOME=%TPTP_AC_HOME%\plugins\org.eclipse.tptp.j avaprofiler
Set PATH=%JAVA_PROFILER_HOME%;%PATH%;%TPTP_AC_HOME%\bin
Set PATH=%PATH%;%JAVA_HOME%\bin
"C:\Program Files\Java\jdk1.5.0_15\bin\java.exe"
-agentlib:JPIBootLoader=JPIAgent:server=standalone,file=c:\t mp\cslog.trcxml;HeapProf:allocsites=true
-Xmx750m "-Dcatalina.base=C:\Documents and
Settings\tom.talbott\workspace\.metadata\.plugins\org.eclips e.wst.server.core\tmp1 "
-Dcatalina.home=C:\var\Tomcat5 "-Dwtp.deploy=C:\Documents and
Settings\tom.talbott\workspace" -Djava.endorsed.dirs=C:\var\Tomcat5\common\endorsed
-classpath "C:\var\Tomcat5\bin\bootstrap.jar;C:\Program
Files\Java\jdk1.5.0_15\lib\tools.jar;C:\var\Tomcat5\common\l ib\vivisimo.jar;C:\var\Tomcat5\common\lib\aspectjweaver.jar; C:\var\Tomcat5\common\lib\commons-el.jar;C:\var\Tomcat5\comm on\lib\glassboxMonitor.jar;C:\var\Tomcat5\common\lib\jasper- compiler.jar;C:\var\Tomcat5\common\lib\jasper-compiler-jdt.j ar;C:\var\Tomcat5\common\lib\jasper-runtime.jar;C:\var\Tomca t5\common\lib\jsp-api.jar;C:\var\Tomcat5\common\lib\naming-f actory.jar;C:\var\Tomcat5\common\lib\naming-factory-dbcp.jar ;C:\var\Tomcat5\common\lib\naming-resources.jar;C:\var\Tomca t5\common\lib\servlet-api.jar "
org.apache.catalina.startup.Bootstrap start
I tried ctrl-break and ctrl-c from the console window and got nothing. The process
appears to be truly locked up. The output file was at 623,115 KB. I used the latest
download I could find for the agent controller (4.4.1).
It might be worth noting that this is a highly multi-threaded server, though the test case
shouldn't be stressing that too bad. Nothing like production.
Anything else I can do to provide information?
-Tom
on 3/27/2008 4:35 PM Tom Talbott said the following:
> Asaf,
> referring to the "Destination" tab in the "Profile on Server" dialog
> when launching Tomcat from within Eclipse? Or, are you referring to
> running the profiling standalone (outside Eclipse)? The only way I've
> and the Tomcat process still locked up. Unfortunately, it locked up to
> the point that I was not able to get StackTrace to dump the threads. I
> can try to set it up in standalone mode to see what happens there,
> -Tom
>> Tom,
>> this case?
>> here?
>> Thanks,
>> Asaf
Re: Profiling Tomcat Servlet - No Events [message #128058 is a reply to message #127568] |
Mon, 07 April 2008 08:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Asaf Yaffe![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=asaf.yaffe%40intel.com) Messages: 333 Registered: July 2009 |
Tom,
Can you please enable logging, repeat the "standalone" test and post the
generated log file here?
To enable logging, define the following environment variables in the
script that runs Tomcat:
set MARTINI_LOGGER_DIRECTORY=<path to an existing directory>
set MARTINI_LOGGER_LOG_LEVEL=5
Asaf
> Follow up:
> it locked up within about a minute of running my test case against the
> server:
> -Djava.endorsed.dirs=C:\var\Tomcat5\common\endorsed -classpath
> The process appears to be truly locked up. The output file was at
> 623,115 KB. I used the latest download I could find for the agent
> controller (4.4.1).
> though the test case shouldn't be stressing that too bad. Nothing like
> production.
> -Tom
>> Asaf,
>> to the point that I was not able to get StackTrace to dump the
>> Thanks,
>> -Tom
>>> Tom,
>>> this case?
>>> here?
>>> Thanks,
>>> Asaf
Re: Profiling Tomcat Servlet - No Events [message #130010 is a reply to message #128058] |
Tue, 13 May 2008 00:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Asaf,
Apologies for not getting back to you on this. I was pulled off onto a different project.
I will try your suggestion this week.
-Tom
on 4/7/2008 1:49 AM Asaf Yaffe said the following:
> Tom,
> Asaf
>> Follow up:
>> server:
>> Set
>> nothing. The process appears to be truly locked up. The output file
>> was at 623,115 KB. I used the latest download I could find for the
>> like production.
>> Thanks,
>> -Tom
>>> Asaf,
>>> Thanks,
>>> -Tom
>>>> Tom,
>>>> this case?
>>>> here?
>>>> Thanks,
>>>> Asaf
Current Time: Sun Jun 30 13:52:42 GMT 2024
Powered by FUDForum. Page generated in 0.04576 seconds
