Home » Archived » COSMOS » How to run the example MDR plugin project ?
How to run the example MDR plugin project ? [message #11586] Mon, 03 November 2008 02:42 Go to next message
Hi ,
I am trying to build my own MDR for my data model using the COSMOS
framework.
I have gone through the
" http://wiki.eclipse.org/Constructing_a_Data_Manager#Data_Man ager_Example"
link and downloaded the required files and trying to set up the
example MDR in my eclipse
work space.
But on the above link the details are not given to run the examples ,
Looking for some help to run this example set up to understand how MDR
works ?
Arun.
Re: How to run the example MDR plugin project ? [message #11622 is a reply to message #11586] Mon, 03 November 2008 10:39 Go to previous messageGo to next message
Originally posted by: david_whiteman.us.ibm.com
Hello Arun,
My apologies... you have stumbled on an outdated document. I have
updated it with a reference to the correct location for this
documentation. Please find the correct documentation linked from the
driver downloads page. You will see links to COSMOS Installation Guide,
COSMOS User's Guide, and COSMOS Developer's Guide. In particular for
building an MDR, you will want to read "Creating a Data Manager" in the
Developer's Guide.
Hope this helps,
David
arunachalam wrote:
> Hi ,
> framework.
> work space.
> MDR works ?
> Regards
> Arun.
Re: How to run the example MDR plugin project ? [message #11657 is a reply to message #11622] Fri, 07 November 2008 06:39 Go to previous messageGo to next message
Hi ,
Thank you for your reply. From the developers I got the link
http://wiki.eclipse.org/COSMOS_DG_Constructing_a_Data_Manage r , is this
the right link to follow ?
I am not able to find the drivers page , can you provide the direct
url ?
Re: How to run the example MDR plugin project ? [message #11693 is a reply to message #11657] Fri, 07 November 2008 15:30 Go to previous message
arunachalam wrote:
> Hi ,
> url ?
I added the following text to the page that links to
COSMOS_DG_Constructing_a_Data_Manager:
"Important Note! This does not represent the most recent level of
documentation. This documentation served as input the documentation
editor, who created an HTML version in the COSMOS CVS repository.
Eventually this HTML version will be accessible on the COSMOS web site.
In the meantime, please consider the HTML files in the CVS repository as
the master source and most current version of the documentation. They
are located in the org.eclipse.cosmos/doc in the technology section of
the repository."
Basically consider any of the user docs on the wiki as backlevel. We
will clean this up soon. In the meantime, you can download the
documentation using the links found here:
http://www.eclipse.org/cosmos/downloads/
David
Re: How to run the example MDR plugin project ? [message #571971 is a reply to message #11586] Mon, 03 November 2008 10:39 Go to previous message
Hello Arun,
Developer's Guide.
Hope this helps,
David
arunachalam wrote:
> Hi ,
> framework.
> work space.
> MDR works ?
> Regards
> Arun.
Re: How to run the example MDR plugin project ? [message #572005 is a reply to message #11622] Fri, 07 November 2008 06:39 Go to previous message
Hi ,
url ?
Re: How to run the example MDR plugin project ? [message #572053 is a reply to message #11657] Fri, 07 November 2008 15:30 Go to previous message
arunachalam wrote:
> Hi ,
> url ?
the repository."
David
Previous Topic:How to run the example MDR plugin project ?
Next Topic:COSMOS 1.0 Release Review
Current Time: Wed Apr 16 09:12:06 EDT 2025
Powered by FUDForum. Page generated in 0.16452 seconds
