Home » Eclipse Projects » Equinox » How to add Tagg Library to jetty under equinox
How to add Tagg Library to jetty under equinox [message #126292] Mon, 23 February 2009 12:34 Go to next message
Before anything, I want to say thanks to this group, I'm being learning a
lot with the answers that I get from this group. :)
I was playing with eclipse equinox and jetty. And I want to add some
custom jsp tags jslt and use them under this platform but I'm don't know
where to look to be able to add them. Does I need to play with web.xml? Is
there an extension point to do this? What do I need to do with my class
path?
Thanks.
Ignacio M.
Re: How to add Tagg Library to jetty under equinox [message #126444 is a reply to message #126292] Wed, 25 February 2009 21:07 Go to previous messageGo to next message
Hi Ignacio,
There's a little bit of information on TLD discovery in the javadoc for
org.eclipse.equinox.jsp.jasper.JSPServlet. Here's the relevant chunk...
* <p>
* TLD discovery is slightly different, to clarify it occurs in one of
three ways:
* <ol>
* <li> declarations found in /WEB-INF/web.xml (found either on the
bundleResourcePath in the bundle or in the ServletContext)</li>
* <li> tld files found under /WEB-INF (found either on the
* <li> tld files found in jars on the Bundle-Classpath (see
org.eclipse.equinox.internal.jsp.jasper.JSPClassLoader)</li >
* </ol>
* </p>
despite the comment this is actually not very different from the regular JSP
TLD lookup algorithm.
Another place to look is at the CVS repo at the following site:
Host: sse-examples.cvs.sourceforge.net
Repository Path: /cvsroot/sse-examples
In particular you might look at the org.eclipse.equinox.jsp.jstl and
org.eclipse.equinox.jsp.jstl.examples projects as they make use of tag
libraries.
HTH
-Simon
"Ignacio M" <nmorenor@gmail.com> wrote in message
news:b20364211c10b88f9cc9048979348430$1@www.eclipse.org...
> path?
> Thanks.
> Ignacio M.
Re: How to add Tagg Library to jetty under equinox [message #126573 is a reply to message #126444] Fri, 27 February 2009 11:44 Go to previous message
Thanks. I think I have some tld's working now. Just need some adjustments.
Ignacio M
Previous Topic:Eclipse Equinox Portal Support
Next Topic:Getting Equinox Transforms (XSLT) to work
Current Time: Wed Apr 16 06:12:58 EDT 2025
Powered by FUDForum. Page generated in 0.02368 seconds
