Home » Archived » BIRT » ChartReportItemUIImpl (reportitem was unable to load ChartReportItemUIImpl)
ChartReportItemUIImpl (reportitem was unable to load ChartReportItemUIImpl) [message #125888] Wed, 08 February 2006 05:36 Go to next message
Originally posted by: gilles.vandaele.advalvas.be
Since I installed the 2.0, I get an exception when loading Eclipse:
An unexpected internal exception occurred.Please see log for detail.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.0.0
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:Plug-in org.eclipse.birt.chart.reportitem was unable to
load class org.eclipse.birt.chart.reportitem.ChartReportItemUIImpl.
And the chart items are no more available in the designer. !!
Env: Eclipse 3.1.1, BIRT 2.0(latest), emf-sdo-xsd-SDK-2.1.0
Bring me back my charts :-{
Re: ChartReportItemUIImpl (reportitem was unable to load ChartReportItemUIImpl) [message #126202 is a reply to message #125888] Wed, 08 February 2006 11:33 Go to previous messageGo to next message
Hi Gilles,
It should work, did you follow the installation steps documented on the web
site? http://www.eclipse.org/birt/phoenix/build/
David
"Gilles" <gilles.vandaele@advalvas.be> wrote in message
news:e00d201e3fb71120fd6a70d69a7fd5be$1@www.eclipse.org...
> Version:2.0.0
Re: ChartReportItemUIImpl - SOLVED - [message #129973 is a reply to message #126202] Tue, 14 February 2006 04:23 Go to previous message
It's fixed now,
restarting eclipse from the command line (not a shortcut) with the -clean
option solved my problem.
Tx.
Previous Topic:Is BIRT_VIEWER_REPORT_ROOT working fine with BIRT 2.0.0?
Next Topic:BIRT 2.0.0 Preview problem
Current Time: Thu Apr 24 22:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.03588 seconds
