Re: The state indicates the bundle is resolved? [message #125759 is a reply to message #125672] |
Tue, 10 February 2009 18:21 |
If this ever happens again, you can try running with the -clean command
line option to see if it will recover without requiring a re-install.
Hope this helps,
Eric
On 2/9/2009 10:05 AM, Miles Daffin wrote:
> Hi All,
> I left Eclipse running over the weekend and my machine got rebooted.
> When I tried to start it again this morning the Ganymede splash appeared
> and then it seemed to hang. Nothing was written to the workspace log but
> I found the information below in a timestamped log in the configuration
> directory.
> Can anyone tell me what has caused this issue? I had no option by to
> reinstall.
> TIA,
> Miles
> !SESSION 2009-02-09 09:02:45.816
> eclipse.buildId=M20080911-1700
> java.version=1.6.0_10
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Framework arguments: -refresh -plugincustomization
> C:\dev\tools\eclipseide\3.4qa\eclipse\configuration\msde-glo bal-eclipse-prefs.ini
> -showlocation
> Command-line arguments: -os win32 -ws win32 -arch x86 -refresh -clean
> -data C:\Documents and
> Settings\radcliff\MSDE\eclipseide\3.4qa\workspaces\default -showlocation
> !ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2009-02-09 09:02:51.394
> !MESSAGE !STACK 0
> org.osgi.framework.BundleException: Exception in
> org.eclipse.equinox.internal.simpleconfigurator.Activator.st art() of
> bundle org.eclipse.equinox.simpleconfigurator.
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
> at
> org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
> at
> org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
> at
> org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
> at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> Caused by: java.lang.IllegalStateException: The state indicates the
> bundle is resolved
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureMessage(AbstractBundle.java:1381)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:257)
> at
> org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.startBundles(ConfigApplier.java:317)
> at
> org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.install(ConfigApplier.java:86)
> at
> org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:12 4)
> at
> org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:13 8)
> at
> org.eclipse.equinox.internal.simpleconfigurator.Activator.st art(Activator.java:48)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
> ... 21 more
> Root exception:
> java.lang.IllegalStateException: The state indicates the bundle is resolved
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: The state indicates the bundle is resolved? [message #126089 is a reply to message #125968] |
Fri, 20 February 2009 15:16 |
On 2/19/2009 6:09 AM, Miles Daffin wrote:
> Hi Eric,
>> command line option to see if it will recover without requiring a
>> re-install.
> I always start eclipse with -clean. From the original message:
>>> C:devtoolseclipseide3.4qaeclipseconfigurationmsde-global-ecl ipse-prefs.ini
>>> -showlocation
>>> -data C:Documents and
>>> SettingsradcliffMSDEeclipseide3.4qaworkspacesdefault -showlocation
> This is happening to increasing numbers of users at my firm. They are
> all being forced to reinstall. Some people are having to reinstall once
> a week. This did not used to happen with 3.3.
> Any more ideas?
Other than to say that I've been using 3.4 for a year now, and the rest
of my team for several months and none of us has experienced a need to
re-install.
Of course Eclispe 3.4 is used by tens of thousands of people every day
for at least the past year. If Bugzilla doesn't have any related bugs
reported, I'd suggest that there might be something that everyone on
your team is doing similarly or some specific setup that causes problems
- I don't know.
Sorry, but this is not a widely reported issue (unless I've missed it in
my quick Bugzilla search).
<shrug>
Eric
Re: The state indicates the bundle is resolved? [message #126304 is a reply to message #126280] |
Mon, 23 February 2009 19:17 |
On 2/23/2009 12:30 PM, Miles Daffin wrote:
>> in my quick Bugzilla search).
> Do you know what the error means?
No, but a stack trace would likely give enough information to start
investigating. If you have a stack trace, open a bug report with as much
information as possible, including the stack.
BTW, using -clean to start Eclipse every time is really not necessary
and will make it a lot slower to start up each time.
Eric
FUDForum. Page generated in 0.03653 seconds
