SSH and CVS [message #11494] |
Fri, 21 January 2005 14:23 |
Originally posted by: vorlonemail-eclipse.yahoo.com
I try to use the sshext method in combination with cvs. Eclipse 3.1M4
(Windows XP) doesn't seem to use my key. The 2048 bit RSA key is
encrypted and I am never asked for the password to the key. Instead I am
being asked for the password to the cvs server.
It was working immediately after I upgraded to Eclipse 3.1M4 (from 3.0).
Then I switched to the ext method using putty, which worked but was too
slow for me. Now I wanted to switch back to extssh and it doesn't work
anymore. Nothing is shown in the error log. Eclipse behaves the same on
two different computers. A direct SSH connection using putty and the
same key in putty format can be established, so it doesn't seem to be a
problem on the server side or with the key.
Does anybody know what I can do to get this working? Is there a way to
get extssh log output?
Thanks in advance,
-Michael
FUDForum. Page generated in 0.08058 seconds
