Home » Modeling » M2T (model-to-text transformation) » Questions about XSD transformation
Questions about XSD transformation [message #11491] |
Fri, 13 April 2007 10:33 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: gabriel.goic.apec.fr
Hi all
Discovering the possibilities of model transformation, I want to add
some platform independency to my Java applications, and thus I want to
ask some simple questions, please find them numbered below.
One of these applications is a simple Web Services-based one, which
converts XML flow inputs to XML flow outputs. I think both can be
considered as models, as they reference their own metamodel : some XSD
files referencing XMLSchema.xsd for the input, some XML files
referencing a custom DTD file for the output.
1) XMLSchema.xsd being an ontology (defines itself) referenced by
metamodels, is it a metametamodel? if yes, how is it related to MOF? I
thought MOF was the only metametamodel but I may be wrong
At the time being, I use Sun's JAXWS & JAXB 2.1 to get the XSD
metamodels converted to Java classes, and then I am able to write
transformation rules programatically to get the input flow (as a Java
object) translated into an output as a Java object.
So, willing to untie business value (i.e these transformation rules)
from technology-specific aspects, I came to the idea of writing the
rules with a tool like ATL (to get a transformation model that would be
the real value of the organization), and then use some code generator to
make it executable on a Java platform.
But I found very few (if any) examples of working with XSD files and
putting the transformation rules at runtime execution inside a JVM
2) Does this kind of mechanism correspond to what is called "model2text"
transformation ?
3) Can this approach be called MDE (Model-driven engineering) ? or is
the name only dedicated to transforming PIM (platform-independent
models) into PSM (platform-specific models), for example starting from
UML and refining it until you get some code ?
4) What could be the quickest way to get things done, in terms of tools
to write transformation rules and generate Java code from it, possibly
without having to rewrite the entire XSD structure in a proprietary
format (like KM3 for ATL) ?
Many thanks for your answers
Gabriel
Re: Questions about XSD transformation [message #11528 is a reply to message #11491] |
Fri, 13 April 2007 10:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------080102020409010209050009
Gabriel,
Comments below.
Gabriel G. wrote:
> Hi all
I think it's a metametamodel, because a .xml file could have a
particular .xsd as its metamodel, and that .xsd has the XMLSchema.xsd
(the XML Schema for Schemas) as its metamodel, so I suppose that makes
the XMLSchema.xsd a metametamodel. Of course the .xml file itself could
be the Ecore.ecore file, which is itself the metametamodel for all
..ecore files, which is in turn are metamodels for .xml files; in this
case the XMLSchema.xsd would a metametametametamodel. Because all this
is relative, i.e., the model of a model is a model, I will often make
the statement, a model is a model is a model, because one person's
metametamodel, will be another person's instance data. Any model that
describes other models and is capable of describing itself will have an
instance that's the self describing model, i.e., XMLSchema.xsd and
Ecore.ecore. I think MOF relates to these in a similar way to how
French and English are related.
> be the real value of the organization), and then use some code
> generator to make it executable on a Java platform.
One of the problems I've heard is that the XSD model is not
serializeable as XMI (it serializes using the well-defined and specified
syntax of .xsd files) and some of the transformation tools rely on the
XMI representation itself for doing transformation.
> "model2text" transformation ?
It sounds more like model to model transformation. The model2text stuff
is usually more template driven producing a text file (which could well
be the syntactic representation of something that can be parsed into a
structured model, making the distinction more subtle).
Yes, I would certainly call it model-driven engineering. I don't think
anyone trademarked that term. :-)
> tools to write transformation rules and generate Java code from it,
> possibly without having to rewrite the entire XSD structure in a
> proprietary format (like KM3 for ATL) ?
That's a good question. I can't comment so much on the best way to
expression transformations. Certainly I've worked on things like
XSDEcoreBuilder which converts XML Schema to Ecore and
SchemaEcoreBuilder which converts Ecore back to XML Schema (with the
design goal being that Ecore -> XSD -> Ecore should be a round trip; XSD
-> Ecore -> XSD is somewhat lossy). You might be interested in this
article.
http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava
Since Ecore can be transformed (via model to text templates) to Java,
the XSD -> Java is supported via XSD -> Ecore -> Java. And since the
Ecore model can be used to read and write conforming instance of the
original XSD, this is a useful way of turning any of your data into a
structured model that's amenable to transformation and then such
transformations could be more focused on the abstract syntactic
structure specified by Ecore as opposed to the low level concrete
syntactic structure specified by XML Schema.
> Gabriel
<html>
<head>
<title></title>
</head>
Gabriel,<br>
<br>
Comments below.<br>
<br>
<br>
Gabriel G. wrote:
<blockquote cite="midevnmb0$jk3$1@build.eclipse.org" type="cite">Hi all
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
could be the Ecore.ecore file, which is itself the metametamodel for
all .ecore files, which is in turn are metamodels for .xml files; in
this case the XMLSchema.xsd would a metametametametamodel. Because all
this is relative, i.e., the model of a model is a model, I will often
make the statement, a model is a model is a model, because one person's
French and English are related.<br>
<blockquote cite="midevnmb0$jk3$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
</blockquote>
specified syntax of .xsd files) and some of the transformation tools
rely on the XMI representation itself for doing transformation.<br>
<br>
</blockquote>
stuff is usually more template driven producing a text file (which
could well be the syntactic representation of something that can be
parsed into a structured model, making the distinction more subtle).<br>
<br>
</blockquote>
anyone trademarked that term. :-)<br>
<br>
</blockquote>
trip; XSD -> Ecore -> XSD is somewhat lossy). You might be
interested in this article.<br>
<blockquote><a
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava"> http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava</a><br>
</blockquote>
since the Ecore model can be used to read and write conforming instance
of the original XSD, this is a useful way of turning any of your data
into a structured model that's amenable to transformation and then such
syntactic structure specified by XML Schema.<br>
<br>
Gabriel
<br>
</blockquote>
<br>
</body>
</html>
--------------080102020409010209050009--
Re: Questions about XSD transformation [message #11565 is a reply to message #11528] |
Fri, 13 April 2007 11:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: mikael.barbero.gmail.com
Hi guys,
See my comments below
Ed Merks wrote:
> Gabriel,
> Comments below.
> Gabriel G. wrote:
>> Hi all
XMLSchema can certainly be considered as a metametamodel. Not to get
confused between XML and modeling stuff, we are trying to make a clear
distinction between technical spaces. I suggest you read this quite old
but good introduction position paper about technical spaces:
http://www.sciences.univ-nantes.fr/lina/atl/www/papers/Posit ionPaperKurtev.pdf
That's right there may be some issues with transforming models
conforming to metamodels generated from XSD. I don't know much about it.
Maybe someone that have already use this kind of transformation can help
you.
Totally agree !! And MDE is not trademarked but MDA(tm) is :)
> article.
As Ed said, XSD -> Ecore should be done very easily. Maybe you will have
to design your output metamodel by hand (the one from your DTD). The
transformation between those metamodels can now be designed with ATL
(taking the 2nd remark into account).
To get the output as an XML document conforming to your DTD, you may use
a metamodel to XML transformation and then our XML extractor as in this
example: http://www.eclipse.org/m2m/atl/atlTransformations/#KM32XML
Do not hesitate to ask question about those examples !
To sum up
You have this scenario:
- some XML documents (say {input-set.xml}) conforming to a XMLSchema
input.xsd as input
- you want to get XML documents (say {output-set.xml}) conforming to a
DTD output.dtd as output
You can do for inputs:
- Use EMF facilities to transform input.xsd to input.ecore
- Then you can load each document from {input-set.xml} with EMF
facilities and have models conforming to input.ecore
For your outputs:
- Define by hand your output.ecore metamodel (should be structurally
quite similar to output.dtd)
- Define an ATL transformation between output.ecore and the XML
metamodel (as in the KM32XML example). This transformation must produce
an XML structure conforming to the DTD
- Use the XML extractor to serialize a model from {output-set.xml}
Then:
- Define the ATL transformation between input.ecore and output.ecore.
(after having checked you can use the input.ecore from input.xsd with ATL)
>> Gabriel
Mikael
PS: KM3 should help you to define your output.ecore metamodel, as it is
a very simple concrete syntax to define metamodel. It is not a
proprietary format and can be transformed into Ecore, MOF 1.4 etc..
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
Current Time: Sat Jul 27 12:18:09 GMT 2024
Powered by FUDForum. Page generated in 0.03187 seconds
