Home » Eclipse Projects » Technology Project and PMC » problems starting Eclipse on Linux Mandrake platform
problems starting Eclipse on Linux Mandrake platform [message #11490] Mon, 22 July 2002 10:59 Go to next message
Originally posted by: gtrofin.covistra.com
Hello everybgody,
I'm trying to execute eclipse on a Linux Mandrake platform.
I used eclipse-SDK-2.0-linux-motif.zip
I get en error :
java.lang.ClassNotFoundException: <path>/startup/jar
at java.lang.Class.forName(Class.java:native)
at java.lang.Class.forName(Class.java:55)an error java.
Please give me a tip.
Gabriel
Re: problems starting Eclipse on Linux Mandrake platform [message #13080 is a reply to message #11490] Sun, 28 July 2002 17:25 Go to previous message
Originally posted by: dcengija_remove_.inet.hr
Gabriel wrote:
> Hello everybgody,
> I get en error :
Looks like your classpath is mis-set. I'm using exactly the same
configuration as you do. This is what I have:
/opt/java/jdk <- this is where the JDK is
JAVA_HOME=/opt/java/jdk
PATH=$PATH:$JAVA_HOME/bin
unpack the zip file, you'll have a directory called 'eclipse'. Change to
that dir and just run ./eclipse (in prompt).
If it doesn't work then we'll need to look a little bit deeper.
Davor Cengija, dcengija_remove_@inet.hr
Re: problems starting Eclipse on Linux Mandrake platform [message #570585 is a reply to message #11490] Sun, 28 July 2002 17:25 Go to previous message
Gabriel wrote:
> Hello everybgody,
> I get en error :
Previous Topic:deians@mobikom.bg
Next Topic:[SWT] MDI applicaiton sample?
Current Time: Wed Apr 16 15:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.03984 seconds
