Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] not finding hibernate.properties
[Teneo] not finding hibernate.properties [message #125356] Fri, 06 June 2008 18:40 Go to next message
Originally posted by: tskaufma.gmail.com
I am using EMF (all in one SDK) 2.4RC3, Teneo SDK 1.0.0RC3 and RCP SDK
3.4RC3 plus a couple other Eclipse 3.4 RC3 plugins in my target platform.
I have a hibernate.properties in the root of a plugin:
net.sf.depcon.core
src/
and in the MANIFEST.MF for the plugin I have:
Eclipse-RegisterBuddy: net.sf.depcon.hibernate
Bundle-ClassPath: .
so the hibernate.properties should be in the root of the classpath, right?
I also have the Hibernate jar and required jars packaged as plugin. In it's
MANIFEST.MF I have:
Eclipse-BuddyPolicy: registered, global
So Hibernate should be able to find the hibernate.properties, but it
doesn't work.
The Teneo docs (which maybe out of date?) say:
Teneo allows you to configure Hibernate in two ways:
Automatically: by placing the properties in the file
"hibernate.properties" in a root directory of the classpath. We use this
method in this tutorial.
Programmatically: by creating a Properties instance and using
HbDataStore.setProperties().
So this should work.. it does with Teneo 0.8.0.v200802122150 and EMF
2.4.0.v200801292000
Trevor Kaufman
Re: [Teneo] not finding hibernate.properties [message #125370 is a reply to message #125356] Fri, 06 June 2008 18:47 Go to previous message
Hi Trevor,
I am quessing a bit but I am surprised that it is possible to read a property file in the root from
another plugin. My feel was that a plugin only allows access to exported packages and I am not sure
if you even can export the root of the package tree...
To be sure, is the hibernate.properties present in the output directory?
gr. Martin
Trevor Kaufman wrote:
> Hello,
> net.sf.depcon.core
> src/
> Bundle-ClassPath: .
> it's MANIFEST.MF I have:
> doesn't work.
> 2.4.0.v200801292000
> Trevor Kaufman
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] not finding hibernate.properties [message #619210 is a reply to message #125356] Fri, 06 June 2008 18:47 Go to previous message
Hi Trevor,
gr. Martin
> Hello,
> net.sf.depcon.core
> src/
> Bundle-ClassPath: .
> doesn't work.
> 2.4.0.v200801292000
> Trevor Kaufman
The Netherlands
Previous Topic:[Teneo] not finding hibernate.properties
Next Topic:[EMF Compare] reference lists seem to be handled differently than containment lists
Current Time: Mon Oct 20 12:30:24 EDT 2025
Powered by FUDForum. Page generated in 0.04921 seconds
