Home » Archived » Test and Performance Tools Platform (TPTP) » How to record Hyperlink with Automated GUI Recorder?
How to record Hyperlink with Automated GUI Recorder? [message #125352] |
Wed, 05 March 2008 06:48 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: nhadt.cybersoft-vn.com
I'm new with TPTP and I would like to know that Automated GUI
Recorder (AGR) allows to record hyperlink?
If no, is there any way to customize it?
I know that we can contribute Widget resolvers through the extension
"org.eclipse.tptp.test.auto.gui.widgetResolver" but I don't know how to
resolve for Hyperlink to get IWidgetId
In MacroCommandShell class, it seems that this class also doesn't
support to create command for Hyperlink action. Is there any way or we
must directly modify this class to support?
Thanks for any help,
Nha
Re: How to record Hyperlink with Automated GUI Recorder? [message #125584 is a reply to message #125352] |
Thu, 06 March 2008 08:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
So far, I have resolved problem of how to record hyperlink with
AGR by customizing as following:
1. Hyperlink: as default, when hyperlink is created, it does not
add listener with event type SWT.Selection. This event type is notified
by playback mechanism of BooleanSelectionCommand class. Thus, to record
hyperlink, we should add listener for hyperlink with SWT.Selection event
type
Listener typedListener = new Listener() {
public void handleEvent(Event event) {
if (SWT.Selection == event.type) {
// do action when hyperlink is clicked
ImageHyperlink hyperlink = new ImageHyperlink(parent,style);
hyperlink.addListener(SWT.Selection, typedListener);
// listener for hyperlink action
IHyperlinkListener hpListerner = new IHyperlinkListener(){
public void linkActivated(HyperlinkEvent e) {
Event event = new Event();
event.widget = m_widget;
// notify to selection listener to handle for this event
hpListerner.notifyListeners(SWT.Selection, event);
public void linkEntered(HyperlinkEvent e) {
public void linkExited(HyperlinkEvent e) {
hyperlink.addHyperlinkListener(hpListerner);
2. Create BooleanSelectionCommand for hyperlink widget: directly
modify MacroCommandShell class to support it as following code:
private AbstractMacroCommand createSelectionCommand(WidgetIdentifier
wid, Event event){
if (event.widget instanceof MenuItem
|| event.widget instanceof Hyperlink
|| event.widget instanceof ToolItem
|| (event.widget instanceof Button
&& !(event.widget instanceof Control
&& ((Control)event.widget).getParent()
instanceof CCombo))){
if (event.x != 0 || event.y != 0 || event.detail != 0){
return new BooleanSelectionCommand(this, wid,
new Point (event.x, event.y), event.detail);
return new BooleanSelectionCommand(this, wid);
return null;
It isn't a very good way for this issue but we can record hyperlink with
AGR.
Does anyone have suggest on this issue?
Nha
PS: I hope that this issue could be resolved in the next release.
Nha Dang wrote:
> Hello,
> Nha
Re: How to record Hyperlink with Automated GUI Recorder? [message #125608 is a reply to message #125584] |
Thu, 06 March 2008 14:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jimmy Jin![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=jimmyjin.jxm%40gmail.com) Messages: 32 Registered: July 2009 |
Member |
Hello, Nha,
I checked Hyperlink source code (actually the AbstractHyperlink), and
find that it listens for the SWT.DefaultSelection event. So if when
playback, the SWT.DefaultSelection event can be sent out, instead of the
SWT.Selection event, then you don't need to make Hyperlink listen for
the SWT.Selection event.
It's better that when recording, something can be put in the script to
identify this should be a SWT.DefaultSelection event. Then when
playback, just simply check this. This needs more modifications in
Can you enter a bug in Bugzilla? Maybe I can provide a patch in future
to fix it completely.
Jimmy Jin
Nha Dang wrote:
> Hello,
> So far, I have resolved problem of how to record hyperlink with AGR
> type
> @Override
> @Override
> @Override
> @Override
> wid, Event event){
> return null;
> AGR.
> Nha
> Nha Dang wrote:
>> Hello,
>> extension "org.eclipse.tptp.test.auto.gui.widgetResolver" but I don't
>> know how to resolve for Hyperlink to get IWidgetId
>> Nha
Re: How to record Hyperlink with Automated GUI Recorder? [message #125742 is a reply to message #125608] |
Fri, 07 March 2008 09:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello Jimmy Jin,
It seems that Hyperlink (actually the AbstractHyperlink) just
handles for event type SWT.DefaultSelection only but has no listener for
this event type.
So if we don't add listener (say SELECTION_LISTENER) with
SWT.DefaultSelection or SWT.Selection event types for hyperlink. How
could AGR record when hyperlink is activated? Because when hyperlink is
activated, it doesn't send event which notifies MacroCommandShell to
create BooleanSelectionCommand for hyperlink action.
In previous implemented code, when hyperlink is activated, I
notify event with SWT.Selection which helps MacroCommandShell to create
BooleanSelectionCommand and let SELECTION_LISTENER handles action
instead of linkActivated() method. When playback,
BooleanSelectionCommand sends SWT.Selection event and SELECTION_LISTENER
will handle for this event.
How about your ideas?
Nha
Jimmy Jin wrote:
> Hello, Nha,
> Jimmy Jin
> Nha Dang wrote:
>> Hello,
>> notified by playback mechanism of BooleanSelectionCommand class. Thus,
>> to record hyperlink, we should add listener for hyperlink with
>> @Override
>> @Override
>> @Override
>> @Override
>> wid, Event event){ if (event.widget instanceof
>> MenuItem
>> instanceof CCombo))){ if
>> wid); }
>> return null;
>> with AGR.
>> Thanks,
>> Nha
>> Nha Dang wrote:
>>> Hello,
>>> we must directly modify this class to support?
>>> Nha
Re: How to record Hyperlink with Automated GUI Recorder? [message #125781 is a reply to message #125742] |
Sun, 09 March 2008 13:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
Hello, Nha,
I don't quite understand your sample code, especially the following lines:
I tried it but the IHyperlinkListener does not have notifyListeners()
method. I think maybe you mistyped something here. Can you give a more
complete code example?
Jimmy Jin
Nha Dang wrote:
> Hello Jimmy Jin,
> this event type.
> In previous implemented code, when hyperlink is activated, I notify
> Nha
> Jimmy Jin wrote:
>> Hello, Nha,
>> the SWT.Selection event, then you don't need to make Hyperlink listen
>> for the SWT.Selection event.
>> Regards,
>> Jimmy Jin
>> Nha Dang wrote:
>>> Hello,
>>> Thus, to record hyperlink, we should add listener for hyperlink with
>>> @Override
>>> @Override
>>> @Override
>>> @Override
>>> MenuItem
>>> wid); }
>>> return null;
>>> with AGR.
>>> Thanks,
>>> Nha
>>> Nha Dang wrote:
>>>> Hello,
>>>> don't know how to resolve for Hyperlink to get IWidgetId
>>>> Nha
Re: How to record Hyperlink with Automated GUI Recorder? [message #125794 is a reply to message #125781] |
Mon, 10 March 2008 04:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hello Jimmy Jin,
Sorry for my mistyped, it is m_widget.notifyListeners(SWT.Selection,
event) instead of hpListerner.notifyListeners(SWT.Selection, event)
Nha
Jimmy Jin wrote:
> Hello, Nha,
> @Override
> Jimmy Jin
> Nha Dang wrote:
>> Hello Jimmy Jin,
>> for this event type.
>> is activated, it doesn't send event which notifies MacroCommandShell
>> to create BooleanSelectionCommand for hyperlink action.
>> create BooleanSelectionCommand and let SELECTION_LISTENER handles
>> action instead of linkActivated() method. When playback,
>> SELECTION_LISTENER will handle for this event.
>> Regards,
>> Nha
>> Jimmy Jin wrote:
>>> Hello, Nha,
>>> to identify this should be a SWT.DefaultSelection event. Then when
>>> future to fix it completely.
>>> Regards,
>>> Jimmy Jin
>>> Nha Dang wrote:
>>>> Hello,
>>>> not add listener with event type SWT.Selection. This event type is
>>>> @Override
>>>> @Override
>>>> @Override
>>>> @Override
>>>> directly modify MacroCommandShell class to support it as following
>>>> code:
>>>> MenuItem
>>>> wid); }
>>>> return null;
>>>> with AGR.
>>>> Thanks,
>>>> Nha
>>>> Nha Dang wrote:
>>>>> Hello,
>>>>> doesn't support to create command for Hyperlink action. Is there
>>>>> any way or we must directly modify this class to support?
>>>>> Nha
Current Time: Mon Jul 22 00:25:16 GMT 2024
Powered by FUDForum. Page generated in 0.92073 seconds
