Home » Archived » BIRT » Cannot close connection
Cannot close connection [message #125340] Tue, 07 February 2006 07:33 Go to next message
Originally posted by: jan.tanis.coas.com
I get the following in my stacktrace after generating a report:
7-feb-2006 13:25:36 org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 0 Milliseconds.
Parameter format not found in the report.
7-feb-2006 13:25:36 org.eclipse.birt.data.engine.impl.DataEngineImpl <init>
INFO: Data Engine starts up
7-feb-2006 13:25:36 org.eclipse.birt.data.engine.odaconsumer.Driver
setLogConfiguration
INFO: ODA driver does not have valid trace logging defined in the
plug-in .options or plugin.xml file.
7-feb-2006 13:25:38
org.eclipse.birt.data.engine.executor.cache.SmartCache populateData
INFO: memoryCacheRowCount is 20000
7-feb-2006 13:25:38
INFO: MemoryCache is used
7-feb-2006 13:25:38
INFO: Time consumed by cache is: 0 second
7-feb-2006 13:25:38
7-feb-2006 13:25:38
7-feb-2006 13:25:38
7-feb-2006 13:25:40 org.eclipse.birt.data.engine.odaconsumer.Connection
close
SEVERE: Cannot close connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Failed to close the
connection.
I/O-uitzondering: Socket closed
org.eclipse.birt.report.data.oda.jdbc.Connection.close(Conne ction.java:286)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.close(OdaConnection.java:327)
org.eclipse.birt.data.engine.odaconsumer.Connection.close(Co nnection.java:177)
org.eclipse.birt.data.engine.executor.DataSource.close(DataS ource.java:263)
org.eclipse.birt.data.engine.executor.DataSource.finalize(Da taSource.java:288)
at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
at java.lang.ref.Finalizer.runFinalizer(Unknown Source)
at java.lang.ref.Finalizer.access$100(Unknown Source)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
Caused by: java.sql.SQLException: I/O-uitzondering: Socket closed
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java: 134)
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java: 179)
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java: 333)
at oracle.jdbc.driver.OracleConnection.close(OracleConnection.j ava:1442)
org.eclipse.birt.report.data.oda.jdbc.Connection.close(Conne ction.java:282)
... 8 more
The reports are fine, but I like a clean console;)
Is this a bug or something?
Regards, Jan.
Re: Cannot close connection [message #126552 is a reply to message #125340] Wed, 08 February 2006 19:19 Go to previous messageGo to next message
It looks like BIRT may be trying to close the jdbc connection twice. It
would be a bug if that's the case, albeit a minor one since it should affect
your report execution.
Can you file a bugzilla report and attach your report design?
thanks,
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"Jan Tanis" <jan.tanis@coas.com> wrote in message
news:dsa43c$17d$1@utils.eclipse.org...
<init>
> setLogConfiguration
> 7-feb-2006 13:25:38
> 7-feb-2006 13:25:38
> 7-feb-2006 13:25:38
> 7-feb-2006 13:25:38
> 7-feb-2006 13:25:38
> 7-feb-2006 13:25:38
> close
> connection.
> at
> at
> at
7)
> at
> at
8)
> at
> ... 8 more
> Regards, Jan.
Re: Cannot close connection [message #126860 is a reply to message #126552] Thu, 09 February 2006 04:20 Go to previous message
Have allready filed it without my report design.
I will attach it as you wish.
> thanks,
Previous Topic:Can i use birt in my project?
Next Topic:how to specify bar width (riser)
Current Time: Wed Oct 29 17:28:53 EDT 2025
Powered by FUDForum. Page generated in 0.04039 seconds
