Server Configuration JBoss [message #125196] |
Sat, 23 July 2005 16:14 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: arupsarkar.yahoo.com
I have configured JBoss 4.0.2 from Window -> Preferences -> Server ->
Installed Runtime, there was some error with jboss specific jar files not
found in the right directories, I fixed all that.
Now I am trying to build the SchoolSchedule example from WTP tutorials,
when I am trying to created the new project the target server drop down
has no values.
Does anybody know the reason for that.
Arup
Re: Server Configuration JBoss [message #125231 is a reply to message #125196] |
Sun, 24 July 2005 02:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sportboy02.software.nju.edu.cn
Arup Sarkar wrote:
> Hi
> not found in the right directories, I fixed all that.
> has no values.
> Regards
> Arup
Check the module version drop down.
Only your target server installed runtime support the module version
that it will show up in drop down box.
HTH
Jason
Re: Server Configuration JBoss [message #125237 is a reply to message #125231] |
Sun, 24 July 2005 03:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks Jason,
I finally got the server which I configured in the drop down list, however
when I am trying to test a jsp page by choosing the option "Run on Server"
I am getting the error "Could not publish to the server".
Arup
Re: Server Configuration JBoss [message #125248 is a reply to message #125237] |
Sun, 24 July 2005 06:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Arup Sarkar wrote:
> Thanks Jason,
> however when I am trying to test a jsp page by choosing the option "Run
> on Server" I am getting the error "Could not publish to the server".
> Regards
> Arup
Where do you get the server configuration file? Is it the one that
someone has posted
into newsgroup before?If yes, I am sure you will not encounter such
errors; if no, I
recommende you to try to use that one because your configuration file
may not be
corresponding to jboss4.0.2
Good luck:-)
Jason
FUDForum. Page generated in 0.03762 seconds
