| Call relation among functions/methods [message #124996] | Mon, 25 October 2004 10:23 |  |
| Eclipse User  |  |  |  |  | Hi, I'm trying to extract call relation among functions using CDT Parser. I
 wrote a class that inherits StructuralParseCallback and overrides
 acceptFunctionReference, enterFunctionBody and exitFunctionBody. When a
 function is entered, its name is stored and all function references within
 the body are functions called by currently entered function body. But,
 this does not work for my small piece of C code. Can you please tell me
 whether it is a problem with Eclipse CDT or my Java code that queries the
 parser ?.
 I commented the call graph problem within the C code itself. You can
 diretly exectue "TestCallGraph", a java code attached below to see the
 call graph for a given C program.
 Thanks for your time.
 Dharma
 #include <string.h>
 typedef char ECHAR;
 void myFunction()
 ECHAR * str = (ECHAR *)"X";
 ECHAR * str2 = (ECHAR *)"XX";
 char * cStr = "Y";
 /* myFunction calling strlen - This works correctly */
 /* I can see "call myFunction strlen" */
 strlen(str);
 /* myFunction calling strlen using ECHAR as argument is completely
 missing - NOT Working*/
 /* I can NOT see "call myFunction strlen" */
 if(strlen(str) + strlen(str2) <= 3) { };
 /* myFunction calling strlen using cStr - This works correctly */
 /* I can see "call myFunction strlen */
 //if (strlen(cStr) + strlen(cStr)) { };
 Java code that access parser:
 import java.io.File;
 import java.util.LinkedHashMap;
 import java.util.Map;
 import org.eclipse.cdt.core.parser.IParser;
 import org.eclipse.cdt.core.parser.IProblem;
 import org.eclipse.cdt.core.parser.IScanner;
 import org.eclipse.cdt.core.parser.ParserFactory;
 import org.eclipse.cdt.core.parser.ParserLanguage;
 import org.eclipse.cdt.core.parser.ParserMode;
 import org.eclipse.cdt.core.parser.ScannerInfo;
 import org.eclipse.cdt.core.parser.ast.IASTFunction;
 import org.eclipse.cdt.core.parser.ast.IASTFunctionReference;
 import org.eclipse.cdt.internal.core.parser.InternalParserUtil;
 import  org.eclipse.cdt.internal.core.parser.StructuralParseCallback ;
 class CMySourceElementRequestor extends StructuralParseCallback {
 private String inputFileName = null; // file to be parsed
 private String currentlyEnteredFunction = null; // name of function that
 is currently entered
 public CMySourceElementRequestor(File inputFileName){
 this.inputFileName = inputFileName.getAbsolutePath();
 public void acceptFunctionReference( IASTFunctionReference reference ) {
 // function calls other functions
 System.out.println("call " + currentlyEnteredFunction + " " +
 reference.getName());
 public void enterFunctionBody(IASTFunction function) {
 currentlyEnteredFunction = function.getName();
 public void exitFunctionBody(IASTFunction function) {
 System.out.println("**** Exiting function body: " + function.getName());
 function.setHasFunctionBody(true);
 public boolean parserTimeout() {
 return false;
 public boolean acceptProblem( IProblem problem ) {
 System.out.println("Parsing problem: " + problem.getMessage());
 System.out.println("Problem at line: " + problem.getSourceLineNumber());
 String src = new String(problem.getOriginatingFileName());
 System.out.println("Originating problem in file: " + src);
 return true;
 public class TestCallGraph {
 private final static String[] incPaths  = getIncludePaths();
 private final static Map definedSymbols = getDefinedSymbols();
 private File srcFile; // C file to be parsed
 private CMySourceElementRequestor mySourceElementRequestor;
 public TestCallGraph(File srcFile) {
 this.srcFile = srcFile;
 mySourceElementRequestor = new CMySourceElementRequestor(srcFile);
 private static String[] getIncludePaths() {
 String[] incPaths = new String[2];
 incPaths[0] = "C:\\cygwin\\usr\\include";
 incPaths[1] = "C:\\cygwin\\lib\\gcc-lib\\i686-pc-cygwin\\3.3.1\\include";
 return incPaths;
 private static Map getDefinedSymbols() {
 Map m = new LinkedHashMap();
 String key = "__IEEE_LITTLE_ENDIAN";
 m.put(key, "");
 return m;
 public void printCallGraph() {
 IScanner myIScanner;
 IParser myIParser;
 /* Create a Scanner */
 myIScanner = ParserFactory.createScanner(
 InternalParserUtil.createFileReader(srcFile.getAbsolutePath( )),
 srcFile.getAbsolutePath(), new ScannerInfo(definedSymbols, incPaths),
 ParserMode.COMPLETE_PARSE, ParserLanguage.C,
 mySourceElementRequestor, null, null);
 /* Create a Parser */
 myIParser = ParserFactory.createParser(myIScanner,
 mySourceElementRequestor, ParserMode.COMPLETE_PARSE,
 ParserLanguage.C, null);
 if (myIParser.parse() == true) {
 System.out.println("Parse successful for file: " +
 srcFile.getAbsolutePath());
 } else {
 System.out.println("Parse unsuccessful for file: " +
 /* Main program */
 if(args.length < 1) {
 System.out.println("Usage: java TestCallGraph <absolute path to a .c
 file>");
 TestCallGraph callGraph = new TestCallGraph(new File(args[0]));
 callGraph.printCallGraph();
FUDForum. Page generated in 0.03825 seconds
