Home » Eclipse Projects » Remote Application Platform (RAP) » FormEditor not painted correctly after minimize
Re: FormEditor not painted correctly after minimize [message #125258 is a reply to message #125091] |
Tue, 17 March 2009 12:52 |
Markus rüger Messages: 369 Registered: July 2009 |
Hi Ivan,
we are using CVS Head working on Win XP SP2 + SP3, Win Server 2003 SP2, Win
2000 SP4.
The problem occurs only in Firefox (we use version 3.0.7, also occurs in
2.0.0.20). The following browsers display everything correctly: IE6,IE7,IE8,
Google Chrome, Safari.
In Vista we experience the same problem, but not steady.
Here more hints (for the above described setups):
- Start the demo again (with my editor included)
- close all views and editors of the demo
- now open my editor
- minimize
- restore
- the editor should now be messed up
Option A to fix layout problem:
- open a second editor, wich should look good initially
- now switch back to the other one
Option B to fix layout problem:
- open a view
- maxize the view
- minimize the view
Now everything seems to be fine again.
So I think there is a repaint missing for firefox somewhere.
Markus
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:gpns6q$okp$1@build.eclipse.org...
> Hi Markus,
> I've just tested it with the Workbench Demo (RAP from CVS HEAD, Vista +
> FF) and your editor instead of existing FooEditor and there are no such a
> problems. Can you test it in the same way - just to make sure that we are
> talking on the same thing. Which version of RAP do you use? OS? Browser?
> Best,
> Ivan
> "Markus Kr??????????????????????" wrote:
>> Hello,
>> the FormdEditor is not painted correctly after it was minimized!
>> Steps to reproduce:
>> - Add the attached form editor to the demo and add an action to open it.
>> - you will see a lable and a text field
>> - now minimize the edtior
>> - now restore the editor
>> - the whole editor content now seems to be shiftet somehow since the
>> label is not visible anymore.
>> I tested this with EditorPart and MultipageEditorPart, too. The problem
>> does not occur in these parts.
>> Regards,
>> Markus
Re: FormEditor not painted correctly after minimize [message #125283 is a reply to message #125269] |
Tue, 17 March 2009 13:50 |
Done!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268975
news:gpo8jm$d24$1@build.eclipse.org...
> Hi Markus,
> with all your hints I've managed to reproduce it 1-2 times in Windows
> Vista SP1. Tested on Windows XP SP3 too with FF 3.0.7 with the same
> result. I can confirm that this happens in FF only - IE, Chrome and
> Safari are not affected. Please add a bugzilla about this issue with
> attached form editor and a link to this post.
> Best,
> Ivan
>> Hi Ivan,
>> Win 2000 SP4.
>> IE6,IE7,IE8, Google Chrome, Safari.
>> - minimize
>> - restore
>> - open a view
>> - maxize the view
>> - minimize the view
>> Regards,
>> Markus
>>> Hi Markus,
>>> a problems. Can you test it in the same way - just to make sure that we
>>> are talking on the same thing. Which version of RAP do you use? OS?
>>> Browser?
>>> Best,
>>> Ivan
>>>> Hello,
>>>> Steps to reproduce:
>>>> it.
>>>> Regards,
>>>> Markus
Current Time: Fri Nov 08 23:11:03 GMT 2024
Powered by FUDForum. Page generated in 0.03138 seconds
