Home » Language IDEs » ServerTools (WTP) » starting server from servers view or run -> run...
starting server from servers view or run -> run... [message #124713] Fri, 22 July 2005 09:19 Go to next message
Originally posted by: mark_lybarger.nospam.yahoo.com
i'm using wtp 0.7rc1, jboss 4.0.0 (plugin from
http://www.davedunkin.com/). i've went into the run->run.. to change the
vm arguments sent to the server on startup. i added some -DMYVAR=MYVAL
items for some kludgy environment variables this application requires.
i've noticed that when i use run-> run.. and select the server, then click
run. it starts ok using the arguments i gave. but if i go to the servers
view, and click the start button, the arguments get reset somehow. does
this happen with other app servers? is this an issue with the jboss
plugin, or with the web tools generic definition?
i realize this problem was discussed prior on this newsgroup, but i
haven't seen mention of a bug report on it and am not aware of the
culprit...
thanks!
Re: starting server from servers view or run -> run... [message #124764 is a reply to message #124713] Fri, 22 July 2005 11:00 Go to previous message
Originally posted by: gercan.removeThis.acm.org
This is a server definition behavior. The current release supports
environment variables added to the end/start.
Gorkem Ercan
> click run. it starts ok using the arguments i gave. but if i go to the
> servers view, and click the start button, the arguments get reset
> somehow. does this happen with other app servers? is this an issue
> with the jboss plugin, or with the web tools generic definition?
> culprit...
> thanks!
Previous Topic:Web Modules not showing up in Server Overview>>modules tab
Next Topic:XML Schema validation
Current Time: Wed Mar 12 15:59:34 EDT 2025
Powered by FUDForum. Page generated in 0.04200 seconds
