Home » Eclipse Projects » DTP » SQL parser standalone?
SQL parser standalone? [message #11392] Fri, 21 April 2006 12:22 Go to next message
Greetings-
I've scanned through the project pages for the SQL parser, and haven't
been able to find an answer... but is the DTP SQL parser something that
can be included in a non-Eclipse application?
I to created a simple app to experiment with it, and it seems to handle
the simple "select * from table" statements, but with anything
semi-complicated, I ran into needing some classes from the Eclipse core
runtime. Am I trying to do something this isn't designed for?
-Michael
Re: SQL parser standalone? [message #11506 is a reply to message #11392] Mon, 24 April 2006 21:02 Go to previous message
Michael,
We haven't tried to run this version of the parser in stand-alone mode.
However, it should be do-able, since the SQL parser has few dependencies
on other plugins. You will need the EMF org.eclipse.emf.ecore plugin,
since the parser actions generate an EMF model, but EMF itself can run
outside Eclipse. The Eclipse runtime dependency probably come from our
dynamic parser registration, lookup, and load mechanism. Your app
probably wouldn't need that, so you could try removing that code and see
if the dependency goes away.
Brian
SQL Tools Development, IBM
Michael McMaster wrote:
> Greetings-
> that can be included in a non-Eclipse application?
> handle the simple "select * from table" statements, but with anything
> core runtime. Am I trying to do something this isn't designed for?
> Thanks
> -Michael
Re: SQL parser standalone? [message #573032 is a reply to message #11392] Mon, 24 April 2006 21:02 Go to previous message
Michael,
Brian
> Greetings-
> Thanks
> -Michael
Previous Topic:SQLExceptionDialog
Next Topic:SQLResultRunnable for UserDefinedFunction (UDF)
Current Time: Mon Nov 03 20:02:54 EST 2025
Powered by FUDForum. Page generated in 0.51107 seconds
