Pigheaded BIRT? [message #124580] |
Mon, 06 February 2006 07:49 |
Originally posted by: jan.tanis.coas.com
Hi all,
I've ran into a pigheaded installment of BIRT. Below here some INFO from
the logging that the BIRT engine throws.
6-feb-2006 8:46:34
org.eclipse.birt.report.model.metadata.StructRefPropertyType validateValue
INFO: The value of the structure property is a string
6-feb-2006 8:46:35 org.eclipse.birt.report.engine.api.impl.EngineTask
validateScalarParameter
SEVERE: The supplied value 4.0 for parameter officeID is not a number.
Report run failed.
So if 4.0 not is a number... what the hack is it then?! Does someone
know what causes this strange issue or is it a bug?
Regards, Jan.
FUDForum. Page generated in 0.04543 seconds
