Home » Eclipse Projects » Remote Application Platform (RAP) » Retrieving RAP internal icons
Retrieving RAP internal icons [message #124491] Fri, 13 March 2009 10:43 Go to next message
how can I retrieve the icons [+] and [-] of a Tree?
I want to implement my own tree widget, but I wish to use the same icons.
Enrico
Re: Retrieving RAP internal icons [message #124515 is a reply to message #124491] Fri, 13 March 2009 10:57 Go to previous messageGo to next message
Enrico,
these images reside in the org.eclipse.rap.rwt.q07 plug-in. E.g.
resources/widgets/rap/tree/plus.gif. Thus you should be able to get
a reference like this:
String name = "resources/widgets/rap/tree/plus.gif";
ClassLoader loader = RWT.class.getClassLoader();
Graphics.getImage( name, loader );
*BUT* with doing so you access implementation details that may
change without advance notice.
HTH
Rüdiger
Enrico Zanaga wrote:
> Thanks
> Enrico
Re: Retrieving RAP internal icons [message #124539 is a reply to message #124515] Fri, 13 March 2009 11:14 Go to previous messageGo to next message
Thank you very much!
I'll do a lot of attention!
Rüdiger Herrmann ha scritto:
> Enrico,
> resources/widgets/rap/tree/plus.gif. Thus you should be able to get a
> *BUT* with doing so you access implementation details that may change
> HTH
> Rüdiger
>> Thanks
>> Enrico
Re: Retrieving RAP internal icons [message #124791 is a reply to message #124539] Mon, 16 March 2009 10:28 Go to previous messageGo to next message
Hi Enrico,
I'm just curious - what are you trying to achieve? Do you want to
implement your own tree widget? If so, what are the reasons for such an
investment?
Cheers and thanks in advance
Benny
>> Enrico,
>> HTH
>> Rüdiger
>>> Hi,
>>> icons.
>>> Thanks
>>> Enrico
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Retrieving RAP internal icons [message #125381 is a reply to message #124791] Tue, 17 March 2009 14:10 Go to previous message
Hi Benny,
the current Tree widget implemented in RAP consumes too much memory in
IE 7. I need to load thousands of items so the Tree is unusable for me.
I've re-implemented my own tree widget using a Table widget with [+] and
[-] icons and spaces to show indentation. This implementation is fast
and memory-saver!
Bye
Enrico
Benjamin Muskalla wrote:
> Hi Enrico,
> investment?
> Benny
>>> Enrico,
>>> HTH
>>> Rüdiger
>>>> Hi,
>>>> icons.
>>>> Thanks
>>>> Enrico
Previous Topic:Table Cell/Columns Spacing
Next Topic:Text and CUSTOM_VARIANT does not set background
Current Time: Sun Oct 19 09:42:58 EDT 2025
Powered by FUDForum. Page generated in 0.30250 seconds
