[p2] Tricks and tips for debugging installation problems [message #124458] |
Wed, 14 January 2009 14:20 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I'm having a struggle getting our features to install into p2-enabled
(Eclipse 3.4 based) applications (Ganymede packages, Rational tools,
etc). I keep running into dependency issues, but the output that p2
gives when it can't install is less than useful.
Are there any tricks or techniques that can help an experienced plugin
developer figure out why his feature won't install? Anything beyond the
cryptic "Cannot find match..." and "Unresolved dependency..." messages
that show up in the error log and the p2 UI...
I have to say, this experience is a major step backwards from what we
had in the pre-3.4 world; I'm not sure if all the blame lies with p2 or
if some of it is due to PDE not being quite caught up, but in any case
it is quite disappointing. I'm not new to Eclipse or plugin development,
either.
Thanks in advance,
Eric
Re: [p2] Tricks and tips for debugging installation problems [message #124670 is a reply to message #124458] |
Sun, 18 January 2009 19:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jconlon.apache.org
I too find p2-enabling my feature based Product non-trivial. A set of
debuging tips would be very useful.
thanks,
John
> either.
> Thanks in advance,
> Eric
Re: [p2] Tricks and tips for debugging installation problems [message #124806 is a reply to message #124458] |
Wed, 21 January 2009 22:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: eclipseng.arthorne.com
As you know from recent bugzilla discussions there is work going on to
improve the usefulness of these messages. In the meantime, the best I
can offer is the following. There are two main types of problems that
can occur:
- "Unresolved dependency" means there is a bundle/feature that
requires another bundle/feature that is not present in any available
repository. This can be a bug in the repository you are using, either
that they are missing a bundle/feature, or missing an associate site
reference to refer to another repository containing the required
bundle/feature.
- "mismatch" or "not compatible" - this means there are two things that
require *different* versions of the same thing, and therefore can't both
be installed successfully. E.g., plugin A requires plugin C with range
[1.0,2.0) and plugin B requires C with range [3.0,4.0). There is no
version of C that will make both A and B happy.
Every time I have seen these errors, it has turned out to be a bug in
the repository data - either a missing or incorrectly specified
dependency, or a missing link to an associated repository containing the
dependency. So if you are seeing these errors with a repository created
by someone else, I encourage you to enter bugs for it.
I realize that these messages are frustrating and painful to resolve.
All I can offer as consolation is that this is more painful in p2
because p2 is actually checking that all dependencies are satisfied
correctly before installing. With Update Manager, you typically had no
problems at install time, but the app would fail in equally difficult to
diagnose ways at runtime when the OSGi resolver did this exact same
analysis and found the mismatch or unsatisfied dependency (the error
messages you see in p2 are a result of invoking the OSGi resolver under
the covers). This didn't bother bleeding edge developers who could live
with a failure or two, but was a genuine problem in commercial products.
> either.
> Thanks in advance,
> Eric
FUDForum. Page generated in 0.02579 seconds
