Problem with escaped Strings in JSP Tags [message #123865] |
Thu, 21 July 2005 03:12  |
Hi all,
I have problems with a lot of JSPs with tags that contain values with
escaped strings like <xxx:sometag name="name" value="<%= (String)
request.getParameter(\"parametername\")"/>
I allway get the error message "Syntax Error on token "Invalid Character",
invalid Expression" where the backslash used to escape the quotes is tagged
as the invalid character.
This errors occures in Eclipse 3.1 with WTP 0.7RC1 and earlier versions as
well, but the JSPs work cause no problems in the application server.
Klaus
Re: Problem with escaped Strings in JSP Tags [message #124529 is a reply to message #124416] |
Fri, 22 July 2005 03:49  |
Thanks for your answers, I opened a bug report for that
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=104767).
Using EL might be a solution for new JSPs, but our project contains about
6000 JSPs where about 1000 of them are affected by this bug, but it is only
a minor inconvenience. But the requirement that the project has to be in
the workspace for a working tag completion is a blocking issue for me.
Klaus
"Srgjan Srepfler" <thisisnot@mymail.com> schrieb im Newsbeitrag
news:dbpavp$ub5$1@news.eclipse.org...
> I think you could use EL to insert params that should at least let you
> do your work.
> >> Character",
> >> tagged
> >> versions as
> > Please open bug reports for problems like these.
http://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20Too ls&component=jst.jsp
FUDForum. Page generated in 0.03056 seconds
