Home » Newcomers » Newcomers » Windows Installation.
Windows Installation. [message #123719] Mon, 12 December 2005 18:50 Go to next message
Originally posted by: kheops.production.gmail.com
hello everybody !
i try to to install to my Portable PC Eclipse 3.*.
i'am under windows XP et i've installed the j2sdk142_10.
when i launch Eclipse, i've this message :
"!SESSION Mon Nov 28 20:03:24 CET 2005
!ENTRY org.eclipse.core.launcher 4 0 2005-11-28 20:03:24.486
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException:
org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:331 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
what's the problem !
i don't find any solutions.
please help me !
thanks for all.
FMP.
Re: Windows Installation. [message #125534 is a reply to message #123719] Thu, 22 December 2005 17:48 Go to previous messageGo to next message
Originally posted by: pmcvicker.mail.mhanet.com
I having the exact same problem and am looking for a solution.
Re: Windows Installation. [message #125558 is a reply to message #123719] Thu, 22 December 2005 19:43 Go to previous messageGo to next message
Randy D. Smith is currently offline Randy D. SmithFriend
You say you've installed the SDK, but is it on your path before any
other Java? Open a Command Prompt window and type "java -version" and
tell us what you see.
RDS
FMP wrote:
> hello everybody !
> !STACK
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> please help me !
> thanks for all.
> FMP.
Re: Windows Installation. [message #125632 is a reply to message #125558] Thu, 22 December 2005 20:26 Go to previous messageGo to next message
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\>java -version
java version "1.5.0_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode, sharing)
The log says:
!SESSION Thu Dec 22 11:24:30 CST 2005
!ENTRY org.eclipse.core.launcher 4 0 2005-12-22 11:24:30.218
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:635)
at org.eclipse.core.launcher.Main.basicRun(Main.java:272)
Re: Windows Installation. - Solved [message #125644 is a reply to message #125632] Thu, 22 December 2005 21:04 Go to previous message
Originally posted by: mcvicker.mail.mhanet.com
I did not unzip the files into their default directories.
Previous Topic:restarting after loading in updates...
Next Topic:Windows Service
Current Time: Wed Feb 05 06:36:14 GMT 2025
Powered by FUDForum. Page generated in 0.05974 seconds
