cvs question [message #123644] |
Tue, 02 December 2003 10:33 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: kaja.cotopia.com
i am currently forced to execute the following command from command line:
cvs update -f -r branch_name module
is it possible to get eclipse to behave during the CVS update as if the
-f
option was used? i need to retrieve the missing files from HEAD if they
are not tagged with branch_name.
Re: cvs question [message #123775 is a reply to message #123644] |
Tue, 02 December 2003 15:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bob.news.gmx.net
"karel herink" <kaja@cotopia.com> schrieb im Newsbeitrag
news:bqhpq5$f20$1@eclipse.org...
line:
> -f
> option was used?
Not AFAIK.
You had better put the missing files on the branch. What you are doing
looks like a quite dirty fix for a not correct branch operation. You can
merge from head quite easily if you like.
robert
Re: cvs question [message #124890 is a reply to message #123775] |
Fri, 05 December 2003 14:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
so in other words it is not possible?
> line:
> > -f
> > option was used?
> Not AFAIK.
> Regards
> robert
FUDForum. Page generated in 0.03846 seconds
