NooBee JSP Question [message #123472] |
Mon, 01 December 2003 21:21 |
Originally posted by: greg.smith.dss.virginia.gov
I downloaded eclipse and myeclipse. neither seem to have the plugins for
jsp's and html. i'm confused. am i supposed to go someplace else and get
plugins for them?
greg
Re: NooBee JSP Question [message #123501 is a reply to message #123472] |
Mon, 01 December 2003 22:05 |
Originally posted by: rsk.email.arizona.edu
MyEclipse should have installed the association between itself and
JSP/HTML pages. If not try right-clicking on the file and selecting
"Open with" and choose the MyEclipse editor.
If not, you can do Preferences->Work Bench->File Associations and set
the association to JSP and HTML manually.
> plugins for them?
> greg
Re: NooBee JSP Question [message #123713 is a reply to message #123501] |
Tue, 02 December 2003 13:55 |
riyad,
thanks for the assist. i was able to associate .jsp and .html files with the
java editor but i didnt get the results i wanted.
i wasnt able to find a html editor for myeclipse. when i edit .jsp files i
dont get syntax coloring or hinting.
shouldnt there be a plug-in for html and jsp?
greg
"Riyad Kalla" <rsk@email.arizona.edu> wrote in message
news:bqgds0$2mr$1@eclipse.org...
> > plugins for them?
> > greg
Re: NooBee JSP Question [message #123863 is a reply to message #123713] |
Tue, 02 December 2003 17:46 |
Geez yea there should, I'm not sure whats wrong. Did you use the
MyEclipseIDE installer? In your <MyEclipseIDE Install
DIR>/eclipse/plugins directory, do you have a whole bunch of plugins?
When you click on Help->About, do you see a My Eclipse icon on that
dialog? When you click on plugin details do you have a whole butt-load
of plugins from Genuitec, LLC listed?
These are all things I have, maybe try rerunning the installer? Do you
have admin privaledges on the machine? Do you have read access to the
plugins in the MyEclipse install dir? Maybe check the Eclipse log file
for reported loading errors?
Best,
Riyad
> riyad,
> greg
>>>plugins for them?
>>>greg
Re: NooBee JSP Question [message #124086 is a reply to message #123863] |
Wed, 03 December 2003 13:51 |
riyad,
ic now, i downloaded eclipse 3.0 not the myeclipse ide plugins. the plugins
are now working.
i'm still disappointed though, the jsp plugin is very anemic. no hinting at
all.
greg
news:bqij7e$ibc$1@eclipse.org...
> Best,
> Riyad
> > riyad,
the
i
> > greg
for
get
> >>>plugins for them?
> >>>greg
Re: NooBee JSP Question [message #124248 is a reply to message #123863] |
Wed, 03 December 2003 18:33 |
okay, i'm a NuB
apparently your code must be syntactically correct before the hinting starts
up. now it works.
many thanks
greg
> Best,
> Riyad
> > riyad,
the
i
> > greg
for
get
> >>>plugins for them?
> >>>greg
FUDForum. Page generated in 0.04294 seconds
