Is there a way to control the size of the applet? [message #123449] |
Sun, 11 December 2005 20:41 |
Originally posted by: khvatov.yahoo.com
Hi, all.
I could not find a way to control the size of the applet when I run it
in Eclipse.
Is there a way to specify the size of an applet when you run it?
Please help.
Thank you.
Alex
Re: Is there a way to control the size of the applet? [message #124049 is a reply to message #123590] |
Wed, 14 December 2005 14:27 |
Thanks, it did.
Alex
Jeff Myers wrote:
> Alex,
> Bring up the launch configuration for your Applet (from the menu select
> Run... instead of Run). On the parameters tab of the run configuration
> there are fields to specify the height and width of the applet.
> Hope this helps,
> - Jeff
FUDForum. Page generated in 0.08181 seconds
