Home » Language IDEs » ServerTools (WTP) » Tomcat server start fails
Tomcat server start fails [message #123379] Wed, 20 July 2005 09:20 Go to next message
Heinz is currently offline HeinzFriend
- I've just upgraded my Eclipse 3.1 with the webtools stuff.
(New to the webtools). Eclipse seem's to be ok.
- Created a new dynamic web project.
- Now I try to run the installed Tomcat 5.5.9,
but I get always a starting error dialogbox, saying
"Several ports (80, 80, 80, 80, 80) required by Tomcat v5.5 Server @
localhost
are already in use. ..... "
If I start the same Tomcat manually (outside of Eclipse)
everything works fine).
Any help?
Heinz
Re: Tomcat server start fails [message #123547 is a reply to message #123379] Wed, 20 July 2005 15:46 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
For a default installation of Tomcat 5.5.9 this error would normally be:
Several ports (8005, 8080, 8009)...
If it really says "Several ports (80, 80, 80, 80, 80)..." then your
sever.xml may be corrupt. The various ports it uses shouldn't all be
assigned to port 80.
Larry
> localhost
> Any help?
> Heinz
Re: Tomcat server start fails [message #123972 is a reply to message #123379] Thu, 21 July 2005 12:25 Go to previous message
Albert Almajano is currently offline Albert AlmajanoFriend
I think your problem is that you have your tomcat started from outside
Eclipse.
You have to stop it outside eclipse and then you can come back to eclipse
and start it inside eclipse.
Hope it helps!!!
Good luck!!!
Previous Topic:Websphere 5.0 adapter ?
Next Topic:Jar dependencies management
Current Time: Sat Dec 21 14:20:25 GMT 2024
Powered by FUDForum. Page generated in 0.03116 seconds
