Home » Eclipse Projects » Eclipse Platform » install/update
install/update [message #122905] Fri, 05 September 2003 01:37 Go to next message
Originally posted by: anhoseok.swc.sec.samsung.co.kr
Hi everybody, I wonder if I can delete all the old versions in the update
so that users can download only latest update. Can anybody help on this
issue?
Ho An.
Re: install/update [message #122908 is a reply to message #122905] Fri, 05 September 2003 02:05 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
Do you mean deleting from the update site or uninstalling the old versions
from a local install ?
The answer is yes for both, if you use M3.
-Dorian
"Ho Seok An" <anhoseok@swc.sec.samsung.co.kr> wrote in message
news:bj8p89$d7k$1@eclipse.org...
> issue?
> Ho An.
Re: install/update [message #122941 is a reply to message #122908] Fri, 05 September 2003 11:55 Go to previous message
Chris Laffra is currently offline Chris LaffraFriend
Publishing a new version:
If you remove the old version from your site.xml file, you can savely
delete the feature and plugin jars for the old version.
Upgrading to a new version:
Once you upgraded to a new version, and you verified everything
works, you can remove the old versions of the plugin and its
feature. Be aware that you no longer can go back to the old
versions, of course.
Chris
"dorian birsan" <dorian@birsan.net> wrote in message
news:bj8qv4$eo0$1@eclipse.org...
> -Dorian
update
> > issue?
> > Thanks,
> > Ho An.
Previous Topic:Q: How to implement undo function?
Next Topic:When is workbench Initialization completed?
Current Time: Sat Nov 09 03:07:25 GMT 2024
Powered by FUDForum. Page generated in 0.02720 seconds
