Home » Eclipse Projects » Buckminster dev » [buckminster-dev] New to Buckminster
[buckminster-dev] New to Buckminster [message #11218] |
Thu, 20 March 2008 19:33 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: hollings.cern.ch
------=_NextPart_000_0025_01C88AC9.972B0E20
Content-Type: text/plain; charset="US-ASCII"
I would first like to mention that I'm interested in contributing whatever I
can find the time to contribute to this project; I had just (a couple of
weeks ago) begun a project that aimed to do what this project has already
done (for the most part) before I knew about Buckminster. My least favorite
thing about programming is trying to resolve dependencies for complex
projects, and as far as I'm concerned, it's worth the effort to make it such
that I can just run a command and have that step done for me. I really like
how you are approaching the problem (although I can't get anything other
than the sample to work myself, but that's a problem in implementation [
which I would like to help with ], not the idea behind it :) ).
If it's ok if I help you guys out, the first thing I'm interested in helping
with, just to get acquainted with the project, is by doing whatever I can to
help smooth out some rough edges in the documentation. This, I thought,
might help me understand everything better, and it would give you someone to
test code coverage, as I'm going to try everything out before I document it.
I would then help as much as I can with the debugging, which would also help
me get acquainted with the code (and, more importantly, the group). After
that, I hope to be in a position to contribute a bit more, if it is desired
of me.
If this is desirable, let me know, and I'll get to work; conversely, if you
wish for me to stay out of the way, that is fine as well :).
Matt Hollingsworth
CERN - CMS (http://cms.cern.ch/)
Content-Type: text/html; charset="US-ASCII"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"PersonName"/>
<!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hello,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p >
font-family:Arial'>I would first like to mention that I’m =
interested in
contributing whatever I can find the time to contribute to this project; =
I had
just (a couple of weeks ago) begun a project that aimed to do what this =
project
has already done (for the most part) before I knew about =
favorite thing about programming is trying to resolve dependencies for =
complex
projects, and as far as I’m concerned, it’s worth the effort =
to
make it such that I can just run a command and have that step done for =
me. I
really like how you are approaching the problem (although I can’t =
get anything
other than the sample to work myself, but that’s a problem in
implementation [ which I would like to help with ], not the idea behind =
it :)
). <o:p></o:p></span></font></p>
font-family:Arial'>If it’s ok if I help you guys out, the first =
thing I’m
interested in helping with, just to get acquainted with the project, is =
by
doing whatever I can to help smooth out some rough edges in the =
I thought, might help me understand everything better, and it would give =
you
someone to test code coverage, as I’m going to try everything out =
before
I document it. I would then help as much as I can with the =
debugging, which
would also help me get acquainted with the code (and, more importantly, =
the
group). After that, I hope to be in a position to contribute a bit =
more, if it
is desired of me.<o:p></o:p></span></font></p>
font-family:Arial'>If this is desirable, let me know, and I’ll get =
to
work; conversely, if you wish for me to stay out of the way, that is =
fine as
well :).<o:p></o:p></span></font></p>
font-family:Arial'>Thanks,<o:p></o:p></span></font></p >
<p class=3DMsoNormal><st1:PersonName w:st=3D"on"><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Matt =
Hollingsworth</span></font></st1:PersonName><font
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span ></font></p=
font-family:Arial'>CERN – CMS =
(http://cms.cern.ch/)<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0025_01C88AC9.972B0E20--
Re: [buckminster-dev] New to Buckminster [message #11298 is a reply to message #11218] |
Thu, 20 March 2008 20:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Matt,
it sounds like we have a lot of common objectives and we would of course welcome your efforts. From
the sound of it, your aim just right. Let me know what I can do do help get you started.
Kind Regards,
Thomas Hallgren
Matt Hollingsworth wrote:
> Hello,
> I would first like to mention that I’m interested in contributing
> whatever I can find the time to contribute to this project; I had just
> project has already done (for the most part) before I knew about
> Buckminster. My least favorite thing about programming is trying to
> resolve dependencies for complex projects, and as far as I’m concerned,
> it’s worth the effort to make it such that I can just run a command and
> have that step done for me. I really like how you are approaching the
> problem (although I can’t get anything other than the sample to work
> myself, but that’s a problem in implementation [ which I would like to
> If it’s ok if I help you guys out, the first thing I’m interested in
> helping with, just to get acquainted with the project, is by doing
> whatever I can to help smooth out some rough edges in the documentation.
> This, I thought, might help me understand everything better, and it
> would give you someone to test code coverage, as I’m going to try
> everything out before I document it. I would then help as much as I can
> with the debugging, which would also help me get acquainted with the
> code (and, more importantly, the group). After that, I hope to be in a
> position to contribute a bit more, if it is desired of me.
> If this is desirable, let me know, and I’ll get to work; conversely, if
> you wish for me to stay out of the way, that is fine as well :).
> Matt Hollingsworth
> CERN – CMS (http://cms.cern.ch/)
Re: [buckminster-dev] New to Buckminster [message #13694 is a reply to message #11218] |
Thu, 03 April 2008 23:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Henrik Lindberg![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=henrik.lindberg%40puppet.com) Messages: 2509 Registered: July 2009 |
Hi Matt!
I just want to chime in with Thomas and Stefan with yet another welcome!
Your offer to help is much appreciated!
- henrik
> Hello,
> Matt Hollingsworth
Current Time: Sat Jul 27 12:27:16 GMT 2024
Powered by FUDForum. Page generated in 0.03538 seconds
