Home » Modeling » GMF (Graphical Modeling Framework) » Getting editing domain from a menu
Getting editing domain from a menu [message #122369] Fri, 27 April 2007 11:30 Go to next message
I think the answer is obvious but I can't find it in the documentation.
How can I get the editing domain and the commands stack from the run
method of an IEditorActionDelegate / ActionDeletage ?
Thanks in advance!
Re: Getting editing domain from a menu [message #122445 is a reply to message #122369] Sat, 28 April 2007 09:06 Go to previous message
it's in the IEditorActionDelegate javadoc:
* Sets the active editor for the delegate.
* Implementors should disconnect from the old editor, connect to the
* new editor, and update the action to reflect the new editor.
* @param action the action proxy that handles presentation portion of
* the action
* @param targetEditor the new editor target
public void setActiveEditor(IAction action, IEditorPart targetEditor);
here you can check if targetEditor is of type *DiagramEditor and then
use the #getEditingDomain() method on it.
ciao,
elm
Previous Topic:One model and multiple diagram editors
Next Topic:Accessing programatically a property of a model element ??
Current Time: Sun Oct 19 03:31:39 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
