Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » org.eclipse.emf.teneo.hibernate has vanished from update site ?
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122481 is a reply to message #122451] |
Wed, 14 May 2008 06:43   |
Hi Guillaume,
Teneo has no dependency on uml2. Can you check if you not accidently also download/install another
feature which uses uml2?
gr. Martin
Guillaume CHATELET wrote:
> Just let me add that Buckminster finds the dependencies by parsing the
> plugin.xml of each features/plugin. So org.eclipse.uml2.examples might
> be a dependency of org.eclipse.emf.teneo . Does it make sense ?
> user@domain.invalid wrote:
>> Hi Martin,
>> Thx for the quick answer.
>> I'm using buckminster to materialize teneo feature and the resolve
>> phase leads to a missing file. Here is the error :
>> Unable to retrieve remote reference
>> " http://download.eclipse.org/modeling/emft/updates/interim/fe atures/org.eclipse.uml2.examples_2.2.0.v200803260935.jar".
>> Server returned HTTP response code: "404 Not Found" for URL:
>> http://download.eclipse.org/modeling/emft/updates/interim/fe atures/org.eclipse.uml2.examples_2.2.0.v200803260935.jar.
>> It seems, either the site.xml contains an error or the file really is
>> missing. Can you check it ?
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> The hibernate and jpox part are distributed together within the Teneo
>>> feature(s). So if you install the Teneo sdk or runtime you should get
>>> it.
>>> Thanks for letting me know about the wrong link. I'll change that.
>>> gr. Martin
>>>> I'd like to add that I used to use this update site :
>>>> http://download.eclipse.org/modeling/emft/updates/site-inter im.xml
>>>> according to installation procedure
>>>> http://www.elver.org/hibernate/installation.html
>>>> But this address is unavailable so I searched a bit and found this
>>>> one as a replacement
>>>> http://download.eclipse.org/modeling/emft/updates/interim/si te.xml
>>>> but this update site contains no org.eclipse.emf.teneo.hibernate
>>>> feature.
>>>>> Hi everyone,
>>>>> Does anyone know why org.eclipse.emf.teneo.hibernate has vanished
>>>>> from interim update site ?
>>>>> There's Teneo but no more teneo.hibernate ...
>>>>> Cheers,
>>>>> Guillaume
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122538 is a reply to message #122481] |
Fri, 16 May 2008 08:14   |
Hi Martin,
I checked it with Thomas Hallgren from Buckminster project :
http://www.eclipse.org/newsportal/article.php?id=132&gro up=eclipse.tools.buckminster#132
The problem is there's an inconsistency in the EMFT site.xml -> http://download.eclipse.org/modeling/emft/updates/interim/si te.xml
Thomas Hallgren wrote:
> You can report that the following features referenced from the site.xml includes the missing uml2.examples feature.
> org.eclipse.emf.search.all.sdk_0.7.0.HEAD.jar
> org.eclipse.emf.search.all.sdk_0.7.0.v200805020316.jar
> org.eclipse.emf.search.all.sdk_0.7.0.v200805031222.jar
Can you fix this ?
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> also download/install another feature which uses uml2?
> gr. Martin
>>> Hi Martin,
>>> Cheers,
>>> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> Teneo feature(s). So if you install the Teneo sdk or runtime you
>>>> should get it.
>>>> gr. Martin
>>>>> feature.
>>>>>> Hi everyone,
>>>>>> Cheers,
>>>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122562 is a reply to message #122538] |
Fri, 16 May 2008 10:08   |
Hi Guillaume,
I am not sure, is this really a Teneo issue? I am not yet convinced about that.
Maybe it is an issue of another EMFT component... (maybe search?)
gr. Martin
> Hi Martin,
> Can you fix this ?
> Cheers,
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Martin
>>> the plugin.xml of each features/plugin. So org.eclipse.uml2.examples
>>> might be a dependency of org.eclipse.emf.teneo . Does it make sense ?
>>>> Hi Martin,
>>>> is missing. Can you check it ?
>>>> Cheers,
>>>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> should get it.
>>>>> gr. Martin
>>>>>> feature.
>>>>>>> Hi everyone,
>>>>>>> Cheers,
>>>>>>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122588 is a reply to message #122562] |
Fri, 16 May 2008 11:25  |
Originally posted by: codeslave.ca.ibm.com
Surprisingly enough, emf.search == EMF Search [0].
(I know, what's up with the logical mapping between feature namespace
and component name?) :)
If EMF Search depends on UML2, just add one of the MDT update sites as
well in order to resolve those dependencies. Choices are listed here [1].
Or, simpler, install from the Ganymede site, since it includes
everything in one site [2]. Or use the bleeding edge staging site [3].
[0] http://www.eclipse.org/modeling/emft/?project=search#search
[1] http://www.eclipse.org/modeling/mdt/updates/
[2] http://download.eclipse.org/releases/ganymede/
[3] http://download.eclipse.org/releases/ganymede/staging/
Nick
Martin Taal wrote:
> Hi Guillaume,
> about that.
> gr. Martin
>> Hi Martin,
>> Can you fix this ?
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> gr. Martin
>>>>> Hi Martin,
>>>>> Cheers,
>>>>> Guillaume
>>>>> Martin Taal wrote:
>>>>>> Hi Guillaume,
>>>>>> should get it.
>>>>>> gr. Martin
>>>>>>> this one as a replacement
>>>>>>> feature.
>>>>>>>> Hi everyone,
>>>>>>>> vanished from interim update site ?
>>>>>>>> Cheers,
>>>>>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618044 is a reply to message #122451] |
Hi Guillaume,
gr. Martin
>> Hi Martin,
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> it.
>>> gr. Martin
>>>> feature.
>>>>> Hi everyone,
>>>>> Cheers,
>>>>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618050 is a reply to message #122481] |
Hi Martin,
Can you fix this ?
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> gr. Martin
>>> Hi Martin,
>>> Cheers,
>>> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> should get it.
>>>> gr. Martin
>>>>> feature.
>>>>>> Hi everyone,
>>>>>> Cheers,
>>>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618053 is a reply to message #122538] |
Hi Guillaume,
gr. Martin
> Hi Martin,
> Can you fix this ?
> Cheers,
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Martin
>>>> Hi Martin,
>>>> Cheers,
>>>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> should get it.
>>>>> gr. Martin
>>>>>> feature.
>>>>>>> Hi everyone,
>>>>>>> Cheers,
>>>>>>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618056 is a reply to message #122562] |
Nick
Martin Taal wrote:
> Hi Guillaume,
> about that.
> gr. Martin
>> Hi Martin,
>> Can you fix this ?
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> gr. Martin
>>>>> Hi Martin,
>>>>> Cheers,
>>>>> Guillaume
>>>>> Martin Taal wrote:
>>>>>> Hi Guillaume,
>>>>>> should get it.
>>>>>> gr. Martin
>>>>>>> feature.
>>>>>>>> Hi everyone,
>>>>>>>> Cheers,
>>>>>>>> Guillaume
Current Time: Fri Apr 25 02:02:05 EDT 2025
Powered by FUDForum. Page generated in 0.04767 seconds
