Width of palette when using PaletteGroup and PalleteDrawer [message #122213] |
Sun, 14 March 2004 21:48 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: cwhite.ic.net
I have a palette that contains PaletteGroups and and a PaletteDrawer. When
the palette is displayed the palette width is insufficient to display the
entire label for the PaletteDrawer. Everything looks good if I use all
PalletteDrawers.
Is there some property I can set that will cause the palette to display with
its width sized to contain the longest label?
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122331 is a reply to message #122213] |
Mon, 15 March 2004 14:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
It turns out the the width of the palette is fine if the intial state of the
drawer is OPEN and the drawer contains some items with labels that are at
least as long as the drawer label.
It must be that the palette doesn't pay the the drawer label win making its
sizing decisions.
Should I report this as a bug?
"Chris White" <cwhite@ic.net> wrote in message
news:c32jnh$s3m$1@eclipse.org...
> PalletteDrawers.
with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122396 is a reply to message #122331] |
Mon, 15 March 2004 15:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
What is your basis for asking hte palette its width?
Are you calling getPreferredSize or computeBounds?
news:c34eg7$pbi$1@eclipse.org...
the
its
> sizing decisions.
When
the
> > PalletteDrawers.
> with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122658 is a reply to message #122396] |
Tue, 16 March 2004 16:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I am not asking the palette for its size. I am letting the palette size
itsself inside a composite that uses a grid layout (my own - I am not using
GraphicalEditorWithPalette). As I mentioned below the palette sizes properly
as long as the drawers is initially OPEN and it has a label that at least as
"Randy Hudson" <none@us.ibm.com> wrote in message
news:c34g7u$ru3$1@eclipse.org...
> the
> its
> > sizing decisions.
> When
> the
> > > PalletteDrawers.
display
> > with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122678 is a reply to message #122669] |
Tue, 16 March 2004 19:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thank you for the response.
It doesn't make sense to me that the collapsed (or expanded) drawer would
not be wide enough to display its own label. In my opinion this is a bug
(albiet a very tiny bug!).
I could write the code to calculate the preferred palette width but I would
attempt to cycle through the pallete looking for the longest label. It looks
like the pallete code is already something like this but as you point out
the preferred size for a collapse drawer doesn't take the length of its
label into account.
I am going to show my ignorance here. How would I set the pallete width
hint?
Having said all that, I have a better idea how this works and I appreciate
the info.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:c37gfa$fck$1@eclipse.org...
> So, what you are saying is that the GridLayout is probably invoking
> computeBounds on the palette's FigureCanvas, which in turn is invoking
> getPreferredSize() on the palette. The problem here is that DrawerFigure
> (in its getPreferredSize(int, int) method) returns its minimum size --
> effectively, the preferred size of its header -- when not expanded, and
> doesn't bother asking its children for their preferred size. I don't
think
> this quite qualifies as a bug, because that is what would be expected of
it.
> I am guessing you're seeing an ellipsis when you expand the drawer with
the
> entry that has the long label. Is that not acceptable?
> Do you support internationalization? What happens when a palette's label
> turns out to be really long in another language?
> I'd suggest that you set an appropriate width hint for the palette.
> news:c37arp$7q9$1@eclipse.org...
> using
> properly
least
> as
state
> of
> > > the
are
> > at
> making
> > > its
> > > > sizing decisions.
> PaletteDrawer.
> > > When
> display
> > > the
> all
> > > > > PalletteDrawers.
> > display
> > > > with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122689 is a reply to message #122678] |
Tue, 16 March 2004 19:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I think I agree. If our layout managers respected figure visibility, then
drawerfigure wouldn't need to override getPreferredSize() at all. Open a
bugzilla. We can fix this for 3.0. If you need a fix for 2.1, the
workaround is to specify a widthHint to the GridData constraint object.
would
looks
> label into account.
> hint?
> the info.
DrawerFigure
> think
> it.
> the
label
size
> > using
> > properly
> least
> > as
> state
> > of
> > > > the
> are
> > > at
> > making
> > > > its
> > > > > sizing decisions.
> > PaletteDrawer.
> > > > When
> > display
> > > > the
use
> > all
> > > > > > PalletteDrawers.
> > > display
> > > > > with
Re: Width of palette when using PaletteGroup and PalleteDrawer [message #122693 is a reply to message #122678] |
Tue, 16 March 2004 20:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Pratik Shah![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ppshah%40us.ibm.com) Messages: 1077 Registered: July 2009 |
news:c37jsb$jr6$1@eclipse.org...
Aah. I misunderstood. I thought you meant that the drawer, in its
collapsed state, wasn't wide enough to completely fit the label of one of
its children (i.e., one of the palette entries inside the drawer). Right,
so the problem is still in getPreferredSize(int, int) in DrawerFigure. I
misspoke earlier when I said that,
when in collapsed state, the drawer's getMinimumSize() effectively returns
the preferred size of the header. A little more digging, and I realized
that it actually returns the minimum size of the header, which isn't wide
enough for the label.
> hint?
GridData data = new GridData();
data.widthHint = 200;
widget.setData(data);
> the info.
DrawerFigure
> think
> it.
> the
label
size
> > using
> > properly
> least
> > as
> state
> > of
> > > > the
> are
> > > at
> > making
> > > > its
> > > > > sizing decisions.
> > PaletteDrawer.
> > > > When
> > display
> > > > the
use
> > all
> > > > > > PalletteDrawers.
> > > display
> > > > > with
FUDForum. Page generated in 0.03252 seconds
