Home » Eclipse Projects » GEF » Getting Logic example to work in Eclipse 2.1.2
Getting Logic example to work in Eclipse 2.1.2 [message #121801] Thu, 11 March 2004 08:37 Go to next message
Hello group,
I've been trying to get logic example to work. I've created a new
plug-in project and then copied logic example sources into that project
and also copied plugin.xml and plugin.properties. Everything compiles
just fine (at least it seems so). The problem occurs when I launch
run-time workbench and try to create a new logic diagram.
The logic diagram wizard is launched and the name of the new diagram is
asked. When I give them and try to get the new diagram generated the
runtime panel at the host eclipse says that uncaught exception has been
thrown. The details are: ClassNotFoundException. That's all, nothing
more. Any guesses?
Something is obviously wrong. Is it just me or is this a general
problem? Is is allowed to just copy the source files into existing
plug-in project? I'm working on Windows and my Eclipse (and gef too)
version is 2.1.2.
All suggestions are highly appreciated.
Regards, Pekka
Re: Getting Logic example to work in Eclipse 2.1.2 [message #121827 is a reply to message #121801] Thu, 11 March 2004 09:33 Go to previous messageGo to next message
<user@domain.invalid> wrote in message news:c2ppsa$t9c$1@eclipse.org...
> Hello group,
Why didn't you just download
http://download.eclipse.org/tools/gef/downloads/drops/R-2.1. 2-200310151343/GEF-examples-I20031015.zip
and unzip it into your eclipse directory - then you could just create a
simple project, example, etc, without running a run-time workbench. If you
want to view/modify the source, then simply right click, Import->External
Plug-ins and Fragments->make sure the box is checked to bring in the source
files, and then choose the logic example plug-in from the list of all your
plug-ins. Another option is to simply download the version you want from
CVS, and this will automatically create a project with the source for you.
> more. Any guesses?
There is probably more details in the .log file of your run-time workbench
workspace .metadata directory.
Re: Getting Logic example to work in Eclipse 2.1.2 [message #121840 is a reply to message #121801] Thu, 11 March 2004 09:42 Go to previous messageGo to next message
Originally posted by: brian.fernandes.codito.com
Hi Pekka,
Don't create a plugin project for logic yourself.
Download the GEF examples - they have both features and plugins folders and
unzip these into your eclipse installtion directory - just like you were
installing a normal plugin. Then import the Logic plugin into your
workspace. Since the source is included with the plugin - you will be able
to browse the source of the Logic plugin - even when you edit the class
files, but you won't be able to modify the source.
You will be able to create logic files in your basic workbench and if you
launch a runtime workbench , Logic will be included in the runtime workbench
too. You can place breakpoints in the Logic source in order to understand it
better.
Ask again if you're still having problems,
Brian.
> Hello group,
> more. Any guesses?
> version is 2.1.2.
> Regards, Pekka
Re: Getting Logic example to work in Eclipse 2.1.2 [message #121973 is a reply to message #121840] Fri, 12 March 2004 05:50 Go to previous message
Thank you Brian and Whitney. Finally I got it to work.
Cheers, Pekka
Brian Fernandes wrote:
> Hi Pekka,
> better.
> Brian.
>>Hello group,
>>more. Any guesses?
>>version is 2.1.2.
>>Regards, Pekka
Previous Topic:get initial figure size
Next Topic:AbstractConnectionCreationTool howto
Current Time: Sat Nov 08 20:42:52 EST 2025
Powered by FUDForum. Page generated in 1.06157 seconds
