Re: classpath to properties files - nested libraries [message #148423 is a reply to message #121628] |
Thu, 23 October 2003 13:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: prasarita.netscape.net
I've encountered this same problem and would be interested to see a
reply. It may be the case that it is necessary to add only (in your
case) the config directory. Do you get a MissingResourceException on
the config/i18n directory if only the config directory is added?
Vijay Ganesan wrote:
> I have .properies files in 2 directories - config/ and config/i18n. In the
> plugin I am developing, I need to add these 2 directories to the list of
> run-time libraries so that they will be in the plugin classpath and the
> properties files will be found. The problem is that I get a Error message
> "cannot nest config/i18n inside of config/" when I try adding config/i18n
> after adding config/
> Is there any way to get around this?
> Thanks
> Vijay
FUDForum. Page generated in 0.02889 seconds
