Home » Newcomers » Newcomers » Ugly Error Message in RunTime
Ugly Error Message in RunTime [message #121622] Sun, 04 December 2005 13:26 Go to next message
Originally posted by: rebecca.levy.mail.mcgill.ca
When running code in Eclipse, the console outputs an incredibly
intimidating error message:
Activation.main: warning: sun.rmi.activation.execPolicy system
property unspecified and no ExecPermissions/ExecOptionPermissions
granted; subsequent activation attempts may fail due to unsuccessful
ExecPermission/ExecOptionPermission permission checks. For
documentation on how to configure rmid security, refer to:
http://java.sun.com/j2se/1.4/docs/tooldocs/solaris/rmid.html
http://java.sun.com/j2se/1.4/docs/tooldocs/win32/rmid.html
the first time I run anything and
Activation.main: an exception occurred: Port already in use: 1098; nested
exception is:
java.net.BindException: Address already in use: JVM_Bind
java.rmi.server.ExportException: Port already in use: 1098; nested
exception is:
at sun.rmi.transport.tcp.TCPTransport.listen(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport.exportObject(Unknown
Source)
at sun.rmi.transport.tcp.TCPEndpoint.exportObject(Unknown Source)
at sun.rmi.transport.LiveRef.exportObject(Unknown Source)
at sun.rmi.server.UnicastServerRef.exportObject(Unknown Source)
at sun.rmi.registry.RegistryImpl.setup(Unknown Source)
at sun.rmi.registry.RegistryImpl.<init>(Unknown Source)
at java.rmi.registry.LocateRegistry.createRegistry(Unknown Source)
at sun.rmi.server.Activation.main(Unknown Source)
Caused by: java.net.BindException: Address already in use: JVM_Bind
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(Unknown Source)
at java.net.ServerSocket.bind(Unknown Source)
at java.net.ServerSocket.<init>(Unknown Source)
sun.rmi.transport.proxy.RMIDirectSocketFactory.createServerS ocket(Unknown
Source)
sun.rmi.transport.proxy.RMIMasterSocketFactory.createServerS ocket(Unknown
Source)
at sun.rmi.transport.tcp.TCPEndpoint.newServerSocket(Unknown Source)
... 9 more
anytime after that. Anyone have a clue what all this means and how to fix
it? Other IDEs (JCreator) run fine.
Re: Ugly Error Message in RunTime [message #121891 is a reply to message #121622] Mon, 05 December 2005 14:41 Go to previous messageGo to next message
> nested exception is: java.net.BindException: Address
> exception is: java.net.BindException: Address already in
> use: JVM_Bind
> Source)
> at
> Source)
> at
> Source)
> ... 9 more
> fix it? Other IDEs (JCreator) run fine.
It seems pretty obvious from the stack trace that your code is using RMI
which is trying to use port 1098, but that port is already in use.
Perhaps your RMI server is already running...
HTH,
Eric
Re: Ugly Error Message in RunTime [message #123056 is a reply to message #121891] Fri, 09 December 2005 15:02 Go to previous message
OK... why would it be running and how would I fix it?
Previous Topic:source and apis
Next Topic:J2EE example code for Eclipse
Current Time: Mon Oct 20 14:38:47 EDT 2025
Powered by FUDForum. Page generated in 0.08800 seconds
