Re: Link Constraint with oclIsKindOf [message #125410 is a reply to message #125057] |
Thu, 10 May 2007 12:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Radomil Dvorak![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dvorak.radek%40gmail.com) Messages: 249 Registered: July 2009 |
Hi Mathias,
Use both type names as qualified, the way Alex has suggested.
As you use two metamodels, it is unclear which package was taken
as the default one for resolving un-qualified names.
If you have tried so already, could you please post a simple test models
that we could reproduce this?
/Radek
On Thu, 10 May 2007 09:39:41 +0200, Mathias Freier
<mathias.freier@gentleware.com> wrote:
> Hello Alex,
> I tried (in several variations: ::, : , fqn ...), but it does not work.
> Mathias
> Alex Shatalin schrieb:
>> Hello Mathias,
>> Try using entity::EntityConstants as a parameter of oclIsKindOf.
>> Alex Shatalin
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Link Constraint with oclIsKindOf [message #129205 is a reply to message #125410] |
Thu, 24 May 2007 10:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bhatia1984.yahoo.com
hiiiii
I am also facing the same prob
I hv two metamodels Tde & UseCase
All the elements in UseCase extends from DiagramElement which i hv defined
in Tde & also the diagram of usecase extends from class which i hv define
in Tde.
By the way UseCase is usecase editor & Tde is statemachine editor.
now when i define
self.ocliskindof(Actor) in usecase it gives error.
but when i define
self.ocliskindof(StartState) in Tde it works fine.
i tried to define
self.ocliskindof(Actor::DiagramElement) but still it gives error.
what i want is that i dnt want any incoming transition on actor
Varun Bhatia
FUDForum. Page generated in 0.04423 seconds
