Home » Eclipse Projects » GEF » understandsRequest unused?
understandsRequest unused? [message #121589] Wed, 10 March 2004 09:51 Go to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I seem this functionality, and I see a utility to make use of it, but I
do not see it being used anywhere!? What is the purpose, and is their a
later version of GEF out for 2.1.2 that uses this?
What is latest version of GEF? is it stable? is there a place I can go
to keep upto date on the GEF happenings?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: understandsRequest unused? [message #121678 is a reply to message #121589] Wed, 10 March 2004 13:33 Go to previous messageGo to next message
Did you try searching? If I search for references I see 8 hits. GEF is
stable.
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:c2n9q6$vjc$1@eclipse.org...
> Respectfully,
> CL Gilbert
Re: understandsRequest unused? [message #121702 is a reply to message #121589] Wed, 10 March 2004 13:42 Go to previous messageGo to next message
* Used to filter EditParts out of the current <i>selection</i>. If an
operation is going
* to be performed on the current selection, the selection can first be
culled to remove
* EditParts that do not participate in the operation. For example, when
aligning the
* left edges of GraphicalEditParts, it makes sense to ignore any selected
* ConnectionEditParts, as they cannot be aligned.
* @param request a <code>Request</code> describing an operation of some
type
* @return <code>true</code> if Request is understood
There are quite a few GEF classes that use it. Eg., NonResizableEditPolicy,
ResizableEditPolicy, DirectEditPolicy, DragGuidePolicy, etc. You can set
breakpoints in these classes to see how exactly
that method is being used.
The last stable build, officially, was 2.1.2. The 2.1.2 maintenance build,
however, should be stable as well. It just adds a few crucial bug fixes to
the 2.1.2 release.
Our homepage is it. This newsgroup is also used to make some announcements.
You might also want to sign up for the GEF mailing list, if you haven't
already done so.
> Respectfully,
> CL Gilbert
Re: understandsRequest unused? [message #121727 is a reply to message #121678] Wed, 10 March 2004 16:04 Go to previous message
Of course I tried searching. I see implementors but only 2 users.
DirectEdit and ToolUtilities.
i checked and see there is GEF v2.1.2, how can I tell whats new in it?
Im using 2.1.1 now.
CL
> stable.
>>Respectfully,
>>CL Gilbert
Respectfully,
CL Gilbert
Previous Topic:draw2d polylihne
Next Topic:Large diagram with a large number of EditParts
Current Time: Tue Jul 01 07:54:49 EDT 2025
Powered by FUDForum. Page generated in 0.18407 seconds
