Home » Archived » Visual Editor (VE) » VE doesn't show source code of readonly files
VE doesn't show source code of readonly files [message #121494] Thu, 06 April 2006 08:01 Go to next message
Originally posted by: johannes.testori.shark-soft.com
hi all,
we are working with a version control system with exclusive checkouts. so
all files are by default read-only on the local hard disk.
the problem is that eclipse doesn't show the source code of readonly files
that are opened with the VE, but just shows "Exception running validator
code".
is it possible to change this behaviour? that would be very important for
us.
kind regards,
hannes
Re: VE doesn't show source code of readonly files [message #121504 is a reply to message #121494] Thu, 06 April 2006 10:18 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
That is a bug. For now the worksaround is the first thing you should do
is select something in the Java Beans Viewer. After that everything will
be fine for that editor.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132199
Rich Kulp
Re: VE doesn't show source code of readonly files [message #121512 is a reply to message #121504] Thu, 06 April 2006 10:54 Go to previous messageGo to next message
the source code is shown when th VE opens the class. But as soon as i
select a widget, the source code is gone. selecting something in the
javabeans viewer first doesn't help. the exception in the error log is the
same as in the bug #132199.
i'm using VE 1.1 and swing.
Re: VE doesn't show source code of readonly files [message #121520 is a reply to message #121512] Thu, 06 April 2006 11:05 Go to previous messageGo to next message
Step up to VE 1.2 I20060405 driver and use Eclipse SDK 3.2M6, and the
latest EMF and GEF builds. With that driver you can click on the java
beans tree first and it will work.
> the same as in the bug #132199.
Rich Kulp
Re: VE doesn't show source code of readonly files [message #121533 is a reply to message #121520] Fri, 07 April 2006 02:14 Go to previous messageGo to next message
so no workaround for VE 1.1 and eclipse 3.1.1?
i'm not sure if upgrading to ve 1.2 and eclipse 3.2 is possible for our
customers.
kind regards,
hannes
Re: VE doesn't show source code of readonly files [message #121610 is a reply to message #121533] Fri, 07 April 2006 10:12 Go to previous messageGo to next message
There is no workaround. Sorry.
> customers.
> kind regards,
> hannes
Rich Kulp
Re: VE doesn't show source code of readonly files [message #121935 is a reply to message #121610] Mon, 10 April 2006 02:36 Go to previous messageGo to next message
is it possible to simply replace the class with a working one? or is the
problem too complex?
Re: VE doesn't show source code of readonly files [message #122008 is a reply to message #121935] Mon, 10 April 2006 10:44 Go to previous message
The problem is too complex. The problem is also in GEF, not VE.
Rich Kulp
Re: VE doesn't show source code of readonly files [message #612500 is a reply to message #121494] Thu, 06 April 2006 10:18 Go to previous message
Rich Kulp
Re: VE doesn't show source code of readonly files [message #612502 is a reply to message #121504] Thu, 06 April 2006 10:54 Go to previous message
Re: VE doesn't show source code of readonly files [message #612505 is a reply to message #121512] Thu, 06 April 2006 11:05 Go to previous message
Rich Kulp
Re: VE doesn't show source code of readonly files [message #612509 is a reply to message #121520] Fri, 07 April 2006 02:14 Go to previous message
customers.
kind regards,
hannes
Re: VE doesn't show source code of readonly files [message #612521 is a reply to message #121533] Fri, 07 April 2006 10:12 Go to previous message
> customers.
> kind regards,
> hannes
Rich Kulp
Re: VE doesn't show source code of readonly files [message #612570 is a reply to message #121610] Mon, 10 April 2006 02:36 Go to previous message
Re: VE doesn't show source code of readonly files [message #612581 is a reply to message #121935] Mon, 10 April 2006 10:44 Go to previous message
Rich Kulp
Previous Topic:Containers
Next Topic:Error in Ve : IWAV 0181E parsing error
Current Time: Mon Sep 15 19:33:46 EDT 2025
Powered by FUDForum. Page generated in 0.07470 seconds
