Re: Bootclasspath extension not available, alternative? [message #125359 is a reply to message #121438] |
Sun, 01 February 2009 14:19 |
Originally posted by: sameera.wso2.com
AFAIK, The best solution would be to version javax.xml.stream.*
packages. Then you need to import the correct version in all the bundles
which use the javax.xml.stream.* packages.
Sameera
Ulf H Nielsen wrote:
> I'm using an api (StAX) whos interfaces are part of java6 but not 5. I
> wish to support both versions (need to run on mac) and thus include the
> interfaces. I tried solving it using the fragment-host extension
> bootclasspath, but it does not seem to be available on mac os x.
> What is the alternative..? If I include the interfaces as a regular
> plugin they collide with the jdk provided ones..
> Best regards,
> Ulf Holm Nielsen
FUDForum. Page generated in 0.03857 seconds
