Home » Modeling » GMF (Graphical Modeling Framework) » Possible to map this metamodel with GMF?
Possible to map this metamodel with GMF? [message #121352] Mon, 23 April 2007 15:52 Go to next message
Roger Brechbühl is currently offline Roger BrechbühlFriend
--------------090409090005020503020807
We have a meta model as shown in the attachment. In words: a process contains connections. Every connection is a link between an activity and an
objectstore. Activities and objectstores don't belong to a process because we want to reuse those objects in different processes.
In the diagram editor, we should be able to draw activities and objectstores as nodes and then make a connection as a link between the two nodes (that
means, on one diagram we see one process).
How can we implement that in GMF? Is it even possible based on that metamodel?
Roger
Content-Type: image/gif;
name="process-ecore.gif"
Content-Disposition: inline;
filename="process-ecore.gif"
R0lGODlhzAG0Aff/AP///7CwsJ18L5t7MJd4MJN3Mo51NIlyNoNvN35sOHlq OnRoPHBlPW1k
P/j50ff41qGYbIKGgWpiP6CYbIKFgfj51vj41pV4MYpyNX1sOXJmPQAAAAwM DOvr6wsLC0dH
R3p6evf393t7e0VFRdnZ2TMzMwUFBdfX15eXl1RUVOzs7B8fH+Pj4/X19Y+P j1lZWebm5jEx
MYGBgR0dHdHR0TU1NQQEBAMDA3JychoaGnNzc97e3isrK8fHxxwcHBMTE7Ky smRkZEpKStra
2vz8/Nvb201NTU9PT76+vj09PaioqK6uriMjIw4ODunp6erq6vb29u/v7/j4 +Ojo6AcHB/Hx
8f7+/iEhIZiYmDk5OQICAmVlZdjY2Pv7+0hISFdXV5aWlnV1db29vf39/XR0 dBsbG1tbWxUV
FQEBARAQEBEREeXl5Xh4eDg4OPDw8Hd3d/r6+pubmzs7O0ZGRm9vb4aGhu3t 7RQUFOLi4hIS
EvT09O7u7hcXF5ycnI2NjW5ubq+vr4KCgoWFhURERNTU1Lm5uSwsLAkJCfLy 8mBgYDAwMF9f
X2tra6urq1VVVVZWVlNTU+Hh4ba2th4eHsrKylhYWKenp5CQkNXV1ScnJ/n5 +bS0tJmZmRgY
GIiIiEtLS4mJiRYWFgoKCmFhYXZ2doSEhE5OTsXFxbW1tRkZGZ6enp+fn7e3 t6CgoLi4uC8v
LwYGBioqKikpKSYmJtzc3CQkJLOzs52dnbGxsaGhocjIyFBQUMbGxszMzJqa mqSkpC0tLUxM
TK2trTIyMi4uLuTk5Lu7u2JiYsDAwEBAQOfn51paWnx8fIqKitDQ0JOTkw8P DyAgILy8vCIi
IpWVlX5+fmNjY21tbYODg8vLy6OjozQ0ND8/P8PDwzo6OmdnZ6mpqY6Ojr+/ v2lpaUFBQSgo
KODg4CUlJaqqqqKiogAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAAAAzAG0AQAI/gABCBxIsKDB gwgTKlzIsKHD
hxAjSpxIsaLFixgzatzIsaPHjyBDihxJsqTJkyhTqlzJsqXLlzBjypxJs6bN mzhz6tzJs6fP
n0CDCh1KtKjRo0iTKl3KtKnTp1CjSp1KtarVq1izat3KtavXr2DDegxAtqzZ s2jTql3Ltq3b
t3ADiJ1LN6fcugLv4t3Ld6VeAYADB+aqt6/hwyH/OljM2IEAwogjS96od0Bj xgOgblC4ofDk
z6Ad6iXw4EGFChZQEzi4oTWHDyRYbvBFUNJmh7cRdg7Nu3dCvQUgTBhOvABr gR1AlJBdg8jA
ZLkZRje427d163oNXF5s4LjAECYE/m5wMeMGgBBBmjTZEkIgHBx30vgRSITN mUMv9AiUxMPE
Ck779fefeDr8IhAujNyGnnrsCSRFIqLw0cxt9d2Xn3ieXaehZHodsJ0DB3jX gQjLAbDBCx0I
hIMQTkwxgg4CgTAHHnvQIVAgg7CASCKMCHRHI1JEEoSPQAop3g7AWGHFMEPc tmKLLwoUxidP
TOHFbTjqyCOGG3Y5mV4IlHZaahYgwFprHoxwgngwDJTDEAJxkYNAPsRG0AqE CDQFHwJNckkk
BPkJ6ECbBSOMMJ+YKNCbcc4JQBlFCETCbXjqyaeJGXqpaV16JRABBaCGmoB3 BUV3g3MAdGGD
QDd0UZAN/jfcoMUGaAhEiRF3zACIrbjqKh4ArgxDjDGKAnCqQKqyimoXt8Eq K61cbiotXnop
8KECpBIUXQ6RAkBCGXTaOdAMLCQkSScFnfurFbMY8isA3EoKLgA+dDupQORS l+m0/EIm0AIf
LpAtoQTpYMQTTnhBhkAizMFCFH8IJIgXRXRByAsCVYKJJpuckfHGHb+rrUAG I6ywQKRQmfBt
E1d8cbT9xtyVXgyIiRpqDAws8nnpNRFEewDAQUceargg0Bh1rGCCIo0IZEkm NhhSiNNQS73z
uwv6DHQIiRwSyoRHJ71005jKbPZWejUgwdpsS9CAv2fHXdW+YNEt991KxaX3 /t589+233XgH
XhTgMwtu+FKEw3344kQljjbjkA/luFaTR245TJVjlfnlnKu0uVWfdy46SaFT VfroqI/F1+mp
t54R61HB7vrsE8n+lO20594Q7k3xrvvvB/0t/PDE6w388R/5jjjyzFO2evPQ X6R83tFXX/vz
1mcvGvbad/8b996HT9D0SZEv/uXmH5X++ZCvPzj77LvfOPznyy85/eIXr//+ /OMfvv1CAaD/
4iZAoBRwgDI7oE8UiEB+MZAnD2zgpiKoEwpKsEsWxEkGL3idDdrEgxzsDQhp MsIQgqaEMkGh
CTkEvhX+jn8wjGHfXHhBspQkfTakIQfRckORmEWH/ghMyw1zCJKzABF/QiQd EZPHwyPmr4kj
MWJipOhE7yUxij+cIhWraL0r+hCKTMwiF7sIRi2KMYxnHCPzyvjFLRYxjWo8 3hJR4sY2qjCO
h5ljSuqIxTvicS969Fwgh/hH2g1yj4dUYiFbl8g9vqSRizTcCC0IyUjerYQZ rKQlzYbCDWpy
kw7UIAlBGbhPeq4mfiRl7/yISVVyMpWddGW/TMkSFaZSlvfryR1vicuf8DIv Feylhn4JzGAK
kze0xBwEj3lCYg6El85kpkuSGZNfRlOagpzfArH5kA14IhSiGIUUxEMe82St QUGDj3zoYx/8
6AcA/PEPgOApoHlWyJ0B/pKnRq45PgNysyEbEMIUEkYK8aBIRSxyEYwAICMa 2QgAWdpRjwDw
oyANiaJFumhEt4RRi75OfUGhpiw3YK95baBNi4ITAOQUroJUCgB76tOfAjXT gbw0pgAQ1D6R
ck2RqnIDy1pVsZSFLKG26lWxmlWtAHCrXO2Kqb16qrOUyiunSq98kuMn8kgq KR/sLF7emled
CpIvhKirNugCQFkPctbaadUgWvXpJjfwCSck7A07K1nCFgaAhj0sYgBomcUw BgCNccxjhQUZ
YgX7ssQeliJyReXg3qq7DYACnIkAWnSy9jP3DK1oYVMa06gWtakB4GmlDe3Y SGs1iURWspP9
/mepoPJa2MZWtlKh7PfUp1vc7tYpvQVAbX07StrmLbjEFW5uEYdc2Q7XLr1L buOa+9vlSdeA
1K2uda8Lwexqd7vcFeVVvPvM8Ip3vMs1b3E1NxXy/vG5/myveh8ZwenQcW7z rSUF7TtU3CyE
v+6Fa34RCRP+SsTABBMw6LxnhTCkQQ1ssIJ00ouSc2r2m+EcZ7HueaF0xmc+ rWlNPgcUYgWl
RxToHE95AMDhd8ZzQCHtHhayAIM1tCEOClkEHjaAh0XcbiVPUqh4BErQd210 og2t0c4qaqT+
PqkVUTLRQSGaI4kSyaMB1F4WxCAQMchBISxwxAYgUa7oroRRK3UU/lfD+q6b XmqsIxuIThOc
UuGy1EQoBYCbZTqo6VqvCVUQiBvSAOZHbCAFZQZvSo6VKqECtajvmiq0jOWq OFfVV/09VgCS
1V9JL7WpmM5q9bQwhqOZJyE63kAkfHxcl4D1W+Kxl1eLtdaBwJnOaP1qpAIA 6/7WOl1p9TP0
AC1oQv+XKfCdiF5PZqK63vVdjCWsXyEmkDRwYSCGDRkArD2QkuWC2dGJ9sce a5Rk423LXf7y
eC3IWc1eVhSZfRfSREs2oRHNaAAoBQdug9rW6tvETRBFZ/s779WetmqmLXeA qYICGtsYx0NF
MG+BYgUt9NAr5o6bFciQhjS8QcIR/3EL/tG28O6V/Kp1O3n1VG4RljMk49J0 eUVkvhCY99Lm
yObUgH9D85lTa+dw7bnPfw70vAh96ETf+dFb3peltw+ZhnH64aSO9JETF+fy zSN3sZ51rSeX
6133Om7BHnaxc5PqO/3SP9GedrXHXFMnj46BbyP34LG9gxOkisSps7u7I9Pv bRfKDo7AASp4
wQnuUSeIQyweZzAB5FaYBg02U+J3tVi41ajnJsmelbfyAAlQqAIOzBCjGSm5 v5uJAZcBII3l
0D3ORxZIE0iB5UVyvvNJaQFib72zzTyDsJWgRrHqruc8wfRSk7AGxCN5e9wT pQdJ8EBrlnpU
SytqD9CwgwrS/hCF4cfZ07xqwh2e+t4EFsUHSoiCFapwG96jXiCPuIQLlvEu 4v+aINVQQyEB
n7yi/GAJUrADX3Ab0wZY3PYurmAIhiAN73KAxSJujrUJTcB/dEGBqkMUQMAE NnAFYHAb9gZa
+bZv8jYD0QByt/Fv8iY2o3VwpdV8umOBF7ghLug6M6g4wwSDlIODMeglOgg6 PdgRP+haLlSD
GBdKIRSEO5h3NTR1MYOE1MOETThARCgWTghZSFSF/cdJ8DOFc4GFVvhETNFg DxZhE5ZCcuOF
O+FdM1ZjN5ZjO9Zj1XRJJvcU6AYAXgZmYkZmcSiHXQQVxAYAg1Zoh5Zo01RK KxcV/qRmam6o
aqz2SILDhb4BiSLxh4F4bGb4iGg4TSVXh3foS1OXiX5xcg3HhhCXG3tXiJ+Y O5JIEhvXcR8n
MqfYEqD4OrN4cTTYPrXoQ6oYOauYdLOTi7QoOsBoEsOIEb2YcsBTjMaojJDF jKQjjIxzjG7X
Oc4oGtX4jKNzjQqhjdiYjQonQ+AIRy/ESO+TZZEYjuhYPNMYYwIhGO54E6Ao dFSXjjD0hQAg
AB/yGB+EHQPhjoIhckWoS/ZoGduRGfsYif2YjwBZOP3oj4Cxh0IoEKRhGjdj AatBHa4BG6eE
kAJBkJdhkP4lkF9RGPi4HfroiNcjEMFBHMUhIsqxkSI0/hATOSaqgRCoYAiw EAu2gGs8WYYC
UQwpkAZUIAdAcDURGZAd+SEgiYpHqR3b0R189x3hYSLlxDMMAjTv8WHsZCEu pnn0JE/xOBAr
yZITYBwG0QOpgARSIAapoAtGORHRIQcgoAJr6QVvCRHzSBAzWZEXeRDlcA6W eJevhxCh0yEf
EiJROSIlciIpAgBBFmVJ9lCx11FNxmRBEJYC4ZSXAZUFcQSqMBC3sAvigWHi ZHnt1GFZuU6V
BwAmAAWlwnhWuR6aVZUtlpdiKRxkaZYGoQu1wAO8wBkQgWCFORBhQpFkYiYY uQFpsiZ45iYq
dWfut2c5VVN8VkwxKRAesh2I/lkQd4B4eoJYATVQXlBQxTKZkbkzbRAGOzBb A/GYC8WYN1Jl
PGKbmfkhnFkQ44ANoPANA5GaiydiJuJ4kCd5lBdie3AHjQkHZ5AO9ugpoSIq OpNpQcUqlTYQ
4AdVVoWhuoKZAFCcNFkmB8FoLOZoJdVmxodT7hcdxXAMqZAGy7AGX/WcapZn bkafAJCdl7Gd
BCEFP2AOa/ADGnae76d6AtF63icQ14ANAuEKwTCcAmEt24EtUcmei1Ki9CIu +EKIwAZsHOqg
D0oBo2IQ3TkQTgCeE1osF1p9PQkAyvAH6mYqZxodnmajHlqRyFkQjUAOAjEC 6NBS1ud7wCd8
gwkA/jswA3AAAN8ADk4KAACzHQIzpda3bHxVgBJDMYM1btqWbWfAoVB6GVJa EKawCgOhCkcQ
a131LveXogihB1O5LVYaHbVmo176oGFaEMHQCgLxC4lCaVR6fdm3fd03qADw CNowBpkQAota
M8aJMxG6WT0zcB+IbwW3gv1mWtXKoY16GY9aEKfQCUigCUjQCb/ZbHblBXj1 gJbaWJS6bdcm
EJ+ADCHQAcxQA9XWrgAgqTsTbTbaqY3xqWRqAyVmA1Nwpb16G/E3f/VHENmw Dd1gDcqVkgCg
Nm2zNm9zkNcJAMr6oTlzEEDQH7KAC4TybvFWLNNab5+FbygIAJuQBFTQ/gTB QAsCkbLttjMl
a6PZ2hjbOhDh0IgAcAzh0FcOQ23smmAJuIANaK8AwA3egAwPe5TxdbESO7EV WxEVZ7EMKRAZ
W5EbSxCvIA4EgQyvEDQnG7MiSLIkaIJkmxu2sAISVpj0CI78KBK94CjrdbUR O7EU2xLUAALW
GRH8FI9vG7h7Uzc54QblAKNN67e5dLHsNZKCSzz2+LRQRzmEK5JO64kc6XxI mYaRi7mMi14j
uU0QK7mhIY+Vu0yj67mTq7l2a0yX25AOeYmfu2Cha7mKexAX8CEXwBoooDQx QAMCMXiFd3ji
UQdqwAeAUAd5wAemdXnf9Rn74pAPiVW1i7qv/isQGPAhGMAaiNYCMkCvAPB5 oTd64kEHetAH
HmC+feAuVKYlE0WYcWsQubsdu0sdvWsCvxu8hGd43rkBxou8ysu8W4lPibES YghhIAecBXwQ
0nuSMHm7BpEBNkMmGcAaKiAQLSBUBKF74mEHACAFG+DBUnBq0gm/mVsQ2bsd 20sd3fu9AiG+
okd6JqK+6Xu+7DuZRbQSa/hwiwiHWSi/usu7vgu8hLq/xGsi/5u8y9u8p/lO 5ZW6A6EBeCsB
GpAttwF90jdppphgF2rCsysQErysFlDB1HHBAJDBBsHBJiLCIfzBJHyil5LD KsGJ6oYQYTZm
Wuo8B5HCl7HCpdLC/uALw+Q7w+dbw+sbn+5bEItaEcSHfurHfrCYYPfnxatb EFKMt1UMqVcc
fdMXyZGWVJMmxylBicZmx4aGaKJcEGH8oWRcKmaMxgWhxm0MwiL8xpaiyJ0L l3H2fwE4gJ6M
ri5DWJRcuhjRyOm3foO6xWqVx6l8EokIAGNwagiRaqvWzFE8xZlcsAKBxZ0c cp/8LEv1xNcb
EcSXgRvYgb98GyW7jfHLyLsMgAKYzAkGgdZcEqTskz/szgnmyMiczln6vLuz uJVMEeWsgRwo
zylIb7o4x6vXibJYzO/cywgNzJfaT1Bsu8RMuSoxijzszcQI0Qlmzgftz9Cs gmQjzhBM/ron
9Dgq0Yoeh7Z3Wc/w2IyPuz/tDLqb67oprbqlW9M+vRany7kXbb0DTbsY99N+ k8sYvdIandPQ
NdRC/cWmE9Q6jZcCndGsa4NPPc5RXdT4Vb1dbdXmKNVlx9JELdbsSNYU1rpb vdOiq9axQ9Vt
jdYqDb1mzdbn5dZLbddNjdcz7VZIPTw3bdR+bbV0zdPNFNiKLdd5fdhv7dVT 7biKbTxQXdVM
ndV3bdnbM9aQXdZ9rdkBzdlY3bhO3dgP8beD/dWl/ddcDdos9NmZPdenfdWX TdqFbVt6fda1
jdO3XbeOvdfryNtabdrWONlJfcLCHdvErUvcGHTG/dOMzdoh/sVHc/iJz/0W k0XdfZg60hhA
bJQ9ZZGN4d1B371y3e24wpWLXgTeytXc1ghMwLjehygX7m3Vwyjf0HMX+o0+ fSuD2i1H/f10
iSst5413/B3gBG5FB35J9W2L0ShJDR5FvLg4Bb7bmBiNES7TZ5jhAP2CFM7h 7Nw8IG500LhG
EI46I26MF87dKV51BNTi7z2OL3HAZJgQsClsvwjjuY0SO9yGgendL6Tjs/0S dIzP2IU8Qh7a
LnHPP+5LSV7ZC94SzxzNRs7c0fPkHX4STK7ATr7d3A0TRd7kui3iWI7LL8HR Pq7MayrbV17m
KM0SLv2KHl1isahM/+PmAw538ePm/tWI50BIjdPi50n44EoohVEug0s44Tx4 hDp+3ytU4YSd
2hIE6ZFt4DRE6WsN14luiJI+hI/Y6ZfO6Z0NRBmOhoJOQg3uhaeOSvWNhav+ Qe5dha8Oj83t
hLPO5nrOIbeO6xik68d0jT+I6R4e6Igh7EGe4FG360ee66uj7NPN7NTi7EDe 64Ak7do0TNVu
Xuod7fPlhADGKdZOvZHBX3W+5uZu5Ur3g98enGLe5UVn7CZhYaMJTqW5YU2c eFq5mi8GIKsp
71S5Ys5bS0X3THfnnkMmnuSJJfKJZKb3UNFhmTtj8FLWmDj8wEFB4wl8JuWe imGBZne2Zr1G
KXDsp7g2/mcx2ihsYlMj7xdG0ePLZ+O7CBaMxmmP1mjfTFW8an2g9lRwCmmd BsrhfF9GEeZc
/otg8WomJWuomseqahBn5arysjOTfBK9teUwP+xdga/k+mwUra5Ba4D2qqn1 2m0Hs1f5mq7C
/NFIMeXSfPVYvxUzayIiq1mqtYLRmrasZVoy+6x0PxDrTPVKYfW6IUc6aAVB b9tHQfRuf+xR
p9xFgealyJMbzznwzvKYfRRxDtMRt5rJCIM0F+5daIEyB/o654uePfAuHhYs R/pWt9pmhvp/
3oWVDvtAyHYlx/qRUfkLbFy0/0XRLe69P0VgnXPB7+CwDfzFL+HDPXHJr/bH /q9wzS/0l39b
0U/1n89c1Z9NyY3j2U9HLhdcuh9e4a/Uz979TJnp027+58/73K/+D43+7u7+ ds7+5S//1eRe
f4v7HP/68W//MwEQAQIAIFjQ4EGECRUuZNjQ4UCHESVObAiR4kWMGTVu5NjR 40eQIUV+FDjS
JEaLJ0+mVMlwg8GXCWPGbFnT5k2cImkC2ImTZc6WP4FmFDq0Z8OjQ5UuZdoy 6dCiTTtGlbqQ
ascdRzhQ8eKEIBwcd9L44bnBLMENzphYIWhlGo2XZs3uudPh65knVfXuVQhW LFkAIYI0abIl
BFoUK0zEoIFYMWOCRNicOfRCz9ewY8ue5UlQMGHD/o4XNwYgiYeJFZw0XuUr kXXr1xt5IIFS
BYcZgiDm4NlDBy1MADHEEJRWovNxANewEXQVrPVzvrp5+waAQ4iTKSN0oE3B ooWMGty9gycY
aBALRIkY5d7d+3fBmNaxaxf/PTyAO42kRAqyMTb0hP6rSsCOWjiDIB9IOGin l555gaBKqDmO
ph1mgAOAb8ABcEOmEjwohyEI4iIHtFQgqAUbSjwxRQBWIISgKfhAUEHg4CMI RBFJ5MlEAFAk
aJJLIvGoJA4nIpCpIzHqIQkPzEKDoBu6WBC4PaCxQ4U0opjQoEe0GSOTw4oU 86YoD7qBCIK6
YJHB996z4YYbtNjgSQDK/qzxvTPTXLNGSoy4YwZApkryuUGBKpQiH5SIwooq YvLwzuMeucSF
Zd7bKZtturFmTE5rerSgHIogiIQy2tzSRgBmYAGhT02NKdRRS0Vu1tI6GfJQ vXC1SVeJflhC
ih2+iEmEOViI4g+C0uACVVcMMUSa95Q1iBtvkOn0WpOINRZZAHQw4gknvCDD VXIBEMSLIrog
5EEAtD022WXf8xZcccutBBNNNjnwVmwR4lWlfyMCggkbrgAjJjjoyEMNFwgq hYOZCBpjhmjY
Ou5hmmxZweJ+O+Yo4YUbDmywJoIIk81ZYxqjDsUUaeQrhRl2GOL3Piv55Bot ycQGQwoJKWCo
/ooEujVqQPD4aKTFHNonDpdO+mmoox7J6Zqo5shqqbPWeuuHOsaaKK7DFnvs lb7+GTqzyVZ7
ba/THpJQtuOWe+4A3b4aNrrz1pttIpXmy+69Axc8J8BR2qvwwRNXfGq/B1z8 ccj7Rdw1xyO3
/PKmM2+qb8w791wqzv/efPLPS/889FyRJN101jFHHfSlXm99dtpBkj12pW6v fXfeDT8cqtV7
F17w4AmyW/fhk1fe39R9Kn556OMOPm3ko7c++eoBvin767vnnXvGq37ee/LD Bv/soMYvf32t
zycpffbjjx5wq9WX/36oj9cef/6Hd9tp+/VPgB6jnkkCOEAEYst9/r5DXwId OLsFUgRoB3xg
BZVWvwZaUIOno9q/KLhBEAIIgO8LYQk9tzRdfdCEKwSYQFz4QhjGUIYzpGEN bXjDG7JQhwTM
mwp3+MODWEQAQyQiEbnmQyAmUYgOYGITHSCAIyZRipoDwACc2MQBRHGKW8Qb QQjwgAdUoAIW
GCMBFMIKRcBiFrlQCsoox0U4Vg4ABYDABOx4xwIkpAepcIUmaJGINvonjoNE UkEMcEUmGiAh
pmgFQmwWGp4kZjSigQwAJEMZy2DmL5uJ2MhAczJJMgaJhAShRQ6ASAccICF3 8MpB5JOd7fCk
O/apD3kAYB70qIc90ynXK+kjy/HUYJSk/tSgRRAARjGS0QIISEiePhQiAIxI RT1aE4981KIX
ASBGM5oSqnAUTR1twJo2GCYxK2iRBESAAutkZwIS8oO8mAlNAFBTuVD2pjjN CUpSglRMnFnP
lJXTnA60iAJQqYBFNvJDogIAqexZI1Wxikaoeg+sGiorBgl0oAi0yAJQuYCE nCIVhfAjILv1
rXCNK2XlOle61kUQd3FLWvJCab0CulGchg8ADEDmGMfIAIWg4hWwqIVCbWay h6JqZS17GQBA
JjMAYKxmJEPqTXN61bcRpAES4GpXJdAALWJVrGCjm0bHGj8cplWta2WrWs/6 ViP1EK5zrYhc
6XpX5pUVr3st/ohZs8pXvPp1KoAtnxXCkAY1sIFjC3mKTuUmWMJeCwtZgMEa 2hAHhiwCDxvA
wyJ2ZdfIXi8LwwGAGOTAEBY4YgOQWFXVQBva6DWhCgRxQxpQ+4gNdOezeoWt 9bQwBondILOb
jYRnXcvb3kJPtrS1LVKYhtzkKm+0BDEtbNp6Xexm14bRhR4KKGtZzCKnsced G2S5CyArkCEN
aXiDxWgy3qC89rw4Ne9q5ovV+pL1vvSV736JmV8G+tecAL4IgQUMOQPH9cAD 7u+C4ZjgNzqY
kBCOCIUlvDftZljD2b3whBvcYSV+GMQ/tHBdR8zFEjMkxSde24oV4mIWjw3G eY1xO4ihW+Md
zjiIOLZxeXkMRB0bJMg/zt+GjXzk7RJZyUtmcpOd/GQoR1nKU6Zyla18ZSxn Wctb5nKXQRIQ
ADs=
--------------090409090005020503020807--
Re: Possible to map this metamodel with GMF? [message #121500 is a reply to message #121352] Tue, 24 April 2007 11:31 Go to previous message
Alexander Shatalin is currently offline Alexander ShatalinFriend
Hello Roger,
This will definitely require manual generated code modifications. (In particular
- ??ItemSemanticEditPolicy.getCreateCompleteIncoming???Command - this place
contains definition of source/target objects for the link).
If you are going to represent Process as a diagram element then you should
think on wich ObjectStores/Activities should be visible there.. Possible
solution is to use shortcuts for the corresponding ObjectStore/Activity elements.
Alex Shatalin
Previous Topic:Question on Commands and Connections
Next Topic:problem opening a new editor on double click
Current Time: Wed Feb 05 06:57:31 GMT 2025
Powered by FUDForum. Page generated in 0.02750 seconds
