cannot run MemoryAnalyzer on hp-ux [message #11097] |
Fri, 05 June 2009 03:12 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jaechul Yoo![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=yoojchul%40empal.com) Messages: 2 Registered: July 2009 |
Junior Member |
!SESSION 2009-06-05 11:48:07.041
eclipse.buildId=unknown
java.version=1.5.0.14
java.vendor=Hewlett-Packard Co.
BootLoader constants: OS=hpux, ARCH=ia64_32, WS=motif, NL=en
Command-line arguments: -os hpux -ws motif -arch ia64_32
!ENTRY org.eclipse.osgi 4 0 2009-06-05 11:48:08.129
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"org.eclipse.mat.ui.rcp.application" could not be found in the registry.
The applicati
ons available are: org.eclipse.equinox.app.error,
org.eclipse.ant.core.antRunner,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.ui.ide.workbench, org.eclipse.update.core
standaloneUpdate, org.eclipse.update.core.siteOptimizer,
org.eclipse.mat.api.parse.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Actually I cannot find org.eclipse.mat.ui.rcp.application under mat and
mat/plugins directory. How can I fix the problem and succeed to run
MemoryAnalyzer on hp-ux?
FUDForum. Page generated in 0.04163 seconds
