Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121265] |
Sat, 01 April 2006 11:05 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: chaohongliu.vip.sina.com
I want to develop SWT program with Borland Architect 2006 which inner
Eclipse version is 3.1, So I download the Eclipse 3.1,VE1.1.01 and other
required.
I have successfully installed the VE1.1.01 and Eclipse 3.1. I can programm
with VE in Borland Architect 2006, It really work with swing.
but when I use "Viusal Class" wizardpage to create a new class extends SWT
Composite,it can not show the appearance of the control and show
"java.lang.NoClassDefFoundError".
Regards for any suggestion.
Frank Liu
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121387 is a reply to message #121379] |
Tue, 04 April 2006 00:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks, the following are the error messages.
ERROR DETAIL:
Error 2006-04-04 08:37:00.442 Failed to execute runnable
(java.lang.NullPointerException)
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:90)
org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
SESSION DATA:
eclipse.buildId=I20050627-1435
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product com.borland.tg.primary.architect.feature.tec
Command-line arguments: -os win32 -ws win32 -arch x86 -product
com.borland.tg.primary.architect.feature.tec -data E:\Dragon
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121395 is a reply to message #121387] |
Tue, 04 April 2006 00:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedSing le(XMLSaveImpl.java:1988)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1215)
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1358)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:923)
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Warning 2006-04-04 08:36:43.468 Exception thrown.
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.loadClass(ExpressionProcesserController.java:134)
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(ExpressionProcesserController.java:379)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(ConnectionHandler.java:602)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:493)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:989)
org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:311)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1992)
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121433 is a reply to message #121411] |
Wed, 05 April 2006 12:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Rich Kulp wrote:
> Some of the errors are due to a bad cache problem.
> To clear the cache do:
> 1) Open a VE, then close it and all other VE's.
> 2) Do a Project->Clean...->Clean All... Wait for build to finish.
> 3) Try opening the VE again.
Thanks very much for your replay!
I have tried by as your direction,but it still doesn't work.
there is the error log messgae:
java.lang.NoClassDefFoundError: org.eclipse.swt.widgets.Widget
at java.lang.Class.forName(Unknown Source)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:140)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:391)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:202)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:368)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:267)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:769)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:474)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:461)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEvents(BeaninfoClassAdapter.java:1125)
org.eclipse.jem.java.impl.JavaClassImpl.getEvents(JavaClassI mpl.java:1314)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allEvents(BeaninfoClassAdapter.java:2169)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllEvents(BeaninfoClassAdapter.java:1133)
org.eclipse.jem.java.impl.JavaClassImpl.getAllEvents(JavaCla ssImpl.java:1336)
org.eclipse.ve.internal.java.codegen.java.EventsParser.getAd dSignitures(EventsParser.java:64)
org.eclipse.ve.internal.java.codegen.java.EventsParser.analy ze(EventsParser.java:97)
org.eclipse.ve.internal.java.codegen.java.EventsParser.addEv ents(EventsParser.java:133)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.analyzeEvents(JavaBeanModelBuilder.java:346)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:437)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:832)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:914)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:575)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1881)
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #121440 is a reply to message #121411] |
Wed, 05 April 2006 12:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks very much for your reply.
I have tried as your direction,but it still doesn't work.
There is the message of the error log file:
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612468 is a reply to message #121379] |
Tue, 04 April 2006 00:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
ERROR DETAIL:
... 18 more
SESSION DATA:
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612471 is a reply to message #121387] |
Tue, 04 April 2006 00:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612486 is a reply to message #121411] |
Wed, 05 April 2006 12:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Re: Problem of VE1.1.0.1 with Eclipse 3.1 in Borland Architect 2006 for SWT [message #612487 is a reply to message #121411] |
Wed, 05 April 2006 12:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
FUDForum. Page generated in 0.04814 seconds
