Home » Eclipse Projects » Equinox » Using external config.ini
Using external config.ini [message #120906] Sun, 09 November 2008 07:59
Originally posted by: bitblt.yahoo.com
I have been developing a rather large server-side Equinox application; 50+
bundles
So when I develop I use the built in launcher that automaticly creates the
config.ini
upon the selections I have set in the lauch config. Worked fine at the
begining, but
now I have a stand-alone version that has its defined config.ini. And I
would like to re-use the settings
in the file even from run-time workbench.
Is this something that can be done or does anyone has some other solution
for the problem.
B
Previous Topic:Framework.Bootdelegation
Next Topic:Multiple bundle location
Current Time: Wed Mar 12 00:23:20 EDT 2025
Powered by FUDForum. Page generated in 0.03025 seconds
