Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Broken Reference triggers a diff
[EMF Compare] Broken Reference triggers a diff [message #120699] Wed, 30 April 2008 13:46 Go to next message
David Michonneau is currently offline David MichonneauFriend
Member
I am curious about something: let's say my model can reference other model
files. Let's consider two models A and B, both refering to C.
I have one instance of A and C in the same folder
I have one instance of B in another folder
The reference to C is relative to the same folder in both cases. Now it
seems the diff engine consider that A and B are different, since the
reference in B is not resolved. In fact A and B are similar, so I would
think there should be no diff there. The fact that the reference is broken
is something independent from the model content.
Something worse is that if I copy C in the folder where B is, I still get a
diff on the C reference.
David
Re: [EMF Compare] Broken Reference triggers a diff [message #120715 is a reply to message #120699] Wed, 30 April 2008 14:02 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------020906000204060806030100
David,
This is a know bug (I wonder if a bugzilla has been filed for it though
since we often get this feedback) which we are still trying to find a
way to solve "elegantly" ;).
Feel free to raise a new bugzilla for this if you can't find an existant
one.
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare] Broken Reference triggers a diff [message #120729 is a reply to message #120715] Wed, 30 April 2008 16:23 Go to previous message
Member
I haven't found a similar issue in bugzilla, so I have filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229663
David
"laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:fv9u5o$6b0$1@build.eclipse.org...
> David,
> one.
> Laurent Goubet
> Obeo
> David Michonneau a
Re: [EMF Compare] Broken Reference triggers a diff [message #617961 is a reply to message #120699] Wed, 30 April 2008 14:02 Go to previous message
David,
one.
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare] Broken Reference triggers a diff [message #617963 is a reply to message #120715] Wed, 30 April 2008 16:23 Go to previous message
Member
David
> David,
> one.
> Laurent Goubet
> Obeo
> David Michonneau a
Previous Topic:[CDO] Problem with single Ecore, multiple packages
Next Topic:thread safety of Teneo
Current Time: Wed Jan 15 14:32:03 GMT 2025
Powered by FUDForum. Page generated in 0.02177 seconds
