Home » Newcomers » Newcomers » Help for Eclipse
Help for Eclipse [message #120687] Wed, 30 November 2005 03:07 Go to next message
Originally posted by: tgregory.lanset.com
Hello - I'd appreciate help in resolving the problem outlined below:-
Downloaded eclipse-SDk-3.2m3-win32 and installed okay.
Executing eclipse.exe brings up the JAVA -Eclipse SDK screen. When I hit
the HELP button it provides the pull-down menu: Welcome, Help Contents,
Search, Dynamic Help, etc. When I hit on Help Contents a screen appears
very briefly then the Java - Eclipse SDK screen disappears and a small
message screen appears as shown below:
JVM terminated. Exit code = 1
C:\Windows\system32\javaw.exe
-Xms40m
-Xmx256m
-jar C:\eclipse-SDK-3.2m3-32\eclipse\startup.jar
-osWin32
-wsWin32
-archX86
-launcher C:\eclipse-SDK-3.2m3-32\eclipse\eclipse.exe
-name Eclipse
-showsplash 600
-exitdata e3c_44
-vm C:\Windows\System32\javaw.exe
-vmargs40m
-Xmx256m
-jar C:\eclipse-SDK-3.23-32\eclipse\startup.jar
I've any number of things but to no avail. Any of the pulled down menu
item sdo the same thing. It appears from the message screen that it is
repeating itself, in some sort of a loop.
Thanks for help
Terence
Re: Help for Eclipse [message #120883 is a reply to message #120687] Wed, 30 November 2005 10:58 Go to previous messageGo to next message
Key is the "C:\Windows\system32\javaw.exe" line... you need a real Java
JRE installed ... get it from Sun or IBM or anywhere but the stock M$
Windows one.
RDS
> Downloaded eclipse-SDk-3.2m3-win32 and installed okay. Executing
> eclipse.exe brings up the JAVA -Eclipse SDK screen. When I hit the HELP
> button it provides the pull-down menu: Welcome, Help Contents, Search,
> Dynamic Help, etc. When I hit on Help Contents a screen appears very
> -Xms40m
> -Xmx256m
> -osWin32
> -wsWin32
> -archX86
> -name Eclipse
> -showsplash 600
> -exitdata e3c_44
> -vmargs40m
> -Xmx256m
> Thanks for help
> Terence
Re: Help for Eclipse [message #120900 is a reply to message #120883] Wed, 30 November 2005 14:42 Go to previous messageGo to next message
Thanks for help
But I have a j2re1.4.2_10 downloaded from SUN installed. The regedit
appears okay. The Eclipse won't execute at all without a Java JRE. 'Tis is
a mystery!
cheers
TRG
Re: Help for Eclipse [message #121103 is a reply to message #120900] Thu, 01 December 2005 11:04 Go to previous messageGo to next message
But your original message's error results clearly indicated that the
default Windows javaw.exe was being used... did you add the SUN jre to
your path before executing eclipse??
RDS
> Thanks for help
> is a mystery!
> cheers
> TRG
Re: Help for Eclipse [message #121187 is a reply to message #120900] Thu, 01 December 2005 16:54 Go to previous messageGo to next message
> Thanks for help
> is a mystery!
See this Wiki page - it will enlighten you:
http://eclipsewiki.editme.com/StartupProblems
HTH,
Eric
Re: Help for Eclipse [message #121245 is a reply to message #121103] Fri, 02 December 2005 03:18 Go to previous message
Thanks for reply.
I fixed it by downloading Sun JRE 1.5.0_06. The link on the Eclipse page
for a JRE took me to JRE 1.4.2_10 which I used but apparently it takes the
later version to work.
cheers
TRG
Previous Topic:Question about syntax
Next Topic:support for dynamic code
Current Time: Wed Apr 23 23:02:09 EDT 2025
Powered by FUDForum. Page generated in 0.07432 seconds
