can't install PDE Junit plugin [message #120627] |
Tue, 25 November 2003 04:04 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: eipe.uiuc.edu
I was following along with 'Contributing to Eclipse' by Erich Gamma and Kent
Beck, chapter 12, page 93. I was trying to install the PDE JUnit plugin.
After downloading it and unzipping it into the plugins folder, I'm not quite
sure how to 'install' it. After trying a few things, the extra menu item
under 'Run as' still doesn't show up (which is supposed to happen).
Has anybody had this problem? Or something similar with general installation
of plugins? I've installed plugins before - the CDT for example - and had no
trouble.
Rohit Eipe
Re: can't install PDE Junit plugin [message #120686 is a reply to message #120642] |
Tue, 25 November 2003 05:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: draganch.uiuc.edu
Yes, we did. I was even able to import the binary into my workspace. But the
feature's manifest (which I also imported) gives the following warning:
Plug-in reference 'org.eclipse.pde.junit' cannot be resolved. feature.xml
org.eclipse.pde.junitfeature-feature line 39
Julia
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bpukr7$7le$1@eclipse.org...
> You did restart Eclipse?
> Darins
> "Rohit Eipe" <eipe@uiuc.edu> wrote in message
> news:bpuk7p$779$1@eclipse.org...
> > Hi
> Kent
> quite
> installation
had
> no
> > trouble.
> > Thanks
> > Rohit Eipe
Re: can't install PDE Junit plugin [message #121631 is a reply to message #120686] |
Tue, 25 November 2003 11:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: thomas_maeder.ch.ibm.com
Which eclipse build are you using? The PDE junit plugin wasn't in
earlier builds
Thomas
> Julia
>>Darins
>>>Hi
>>Kent
>>quite
>>installation
> had
>>no
>>>trouble.
>>>Thanks
>>>Rohit Eipe
Re: can't install PDE Junit plugin [message #121783 is a reply to message #121631] |
Tue, 25 November 2003 17:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Eclipse 2.1.1, build id 200306271545
I tried PDE JUnit versions 2.1.5 and 3.0.0. None of them show up in the
Plugin Details in the About box.
Julia
"Thomas M
FUDForum. Page generated in 0.03480 seconds
