Home » Language IDEs » ServerTools (WTP) » Can't create EJB project
Can't create EJB project [message #120572] Wed, 13 July 2005 17:17 Go to next message
I'm trying to explore the (new to me) world of EJBs via the latest WTP
builds, which I thought would help me and the WTP team, but I'm not having
much success. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=102957
Does anyone else see the same bug, and is there an updated version of the
tutorial in the works?
http://www.eclipse.org/webtools/testtutorials/M2/ejbtutorial /buildingejbs.html
Thanks!
- Richard
Re: Can't create EJB project [message #120762 is a reply to message #120572] Thu, 14 July 2005 04:39 Go to previous messageGo to next message
> having much success. See:
> the tutorial in the works?
> Thanks!
> - Richard
Hi Richard,
I alway get this bug when trying to create an EJB project with client. I
only succeeded, when I also checked the option "Add module to EAR". Then
the client is created without exception. Sometimes the client project
does not include the necessary classes and I have to clean (i.e.
explicitly build) the project.
Susanne
Re: Can't create EJB project [message #120779 is a reply to message #120762] Thu, 14 July 2005 08:14 Go to previous messageGo to next message
Originally posted by: harry.raceeend.demon.nl
When I create an EJB Project, I always get this error:
java.lang.reflect.InvocationTargetException.
In the project only an ejbModule/META-INF/ejb-jar.xml is generated,
which always is not correct.
Can you create correct EJB Projects ?
> Susanne
Re: Can't create EJB project [message #120788 is a reply to message #120779] Thu, 14 July 2005 08:24 Go to previous messageGo to next message
It is this InvocationTargetException that occurs, if I want to create an
EJB project with client but uncheck the "Add to EAR..." box. If I also
add the project to an EAR, the EJB project and client project are
generated. As long as you have not added any EJBs, the ejb-jar.xml is
invalid due to the missing <enterprise-beans> entry.
Re: Can't create EJB project [message #120926 is a reply to message #120762] Thu, 14 July 2005 18:45 Go to previous messageGo to next message
I did a fresh install using today's 0714 build, and things seem to be
working for me now.
- Richard
>> Thanks!
>> - Richard
> Hi Richard,
> Susanne
Re: Can't create EJB project [message #120952 is a reply to message #120926] Thu, 14 July 2005 19:55 Go to previous messageGo to next message
Moving along in the tutorial, I'm now at the point where I've created the
Tiger bean, but XDoclet doesn't generate TigerHome etc. I have JBoss 3.2.3
and XDoclet installed, and I checked JBoss (version 3.2) in the XDoclet
prefs. Does the bean project have to be part of an EAR app in the newer
WTP builds, or is there some other common error I may be making?
- Richard
> working for me now.
> Thanks
> - Richard
>>> Thanks!
>>> - Richard
>> Hi Richard,
>> Susanne
Re: Can't create EJB project [message #121228 is a reply to message #120952] Fri, 15 July 2005 14:49 Go to previous message
<blush>
I didn't have "Enable XDoclet builder" checked. D'oh!
> Thanks
> - Richard
>> working for me now.
>> Thanks
>> - Richard
>>>> Thanks!
>>>> - Richard
>>> Hi Richard,
>>> Susanne
Previous Topic:JSP Debugging
Next Topic:RDB - Adding a new database & suppression of schema object lookup
Current Time: Tue Oct 14 02:21:43 EDT 2025
Powered by FUDForum. Page generated in 0.44652 seconds
