how to get the currently used Project [message #120362] |
Tue, 29 November 2005 08:47 |
Originally posted by: Knadine.t-online.de
hi,
can somebody tell me how to get the "active" project? I know there are no
active Projects in Eclipse but only open and closed ones, I mean the
project that is in use. I wrote a plugin and if I click on an action in a
custom popup-menu that I added to the outline page, I want to add some
files to the project I'm currently working with. But how can I get the
project?
thx
sth_Weird
Re: how to get the currently used Project [message #120632 is a reply to message #120362] |
Tue, 29 November 2005 22:02 |
Originally posted by: pete_c_johnson_2.yahoo.com
I had the same need in my plugin and found that, in my case, the
ISelection passed into selectionChanged(IAction, ISelection) in my popup
action evaluated to an IResource. My popup is associated with files, so
I'm not sure yours will be the same for the outline, but if you can get
ahold of the IResource for what was clicked on, you can call
IResource.getProject() to get yourself an IProject. From there you can
add anything you'd like.
Don't forget to call IProject.refreshLocal() when you are done adding
files. That'll add them to the project so they will show up in the
project explorer.
FUDForum. Page generated in 0.07833 seconds
