Home » Archived » Visual Editor (VE) » How to launch Visual Ediitor
How to launch Visual Ediitor [message #10993] Mon, 15 December 2003 15:03 Go to next message
Originally posted by: hans.schwaebli.schwaebli.de
I installed the Visual Editor and started Eclipse.
But how do I launch the VE? I searched for a VE perspective, but there is
none.
So how to use it?
Re: How to launch Visual Ediitor [message #11018 is a reply to message #10993] Mon, 15 December 2003 18:07 Go to previous message
Hi Hans,
> none.
We deliberate didn't create our own perspective, because we view the Visual
Editor as being a supercharged way of editing Java rather than a whole new
way. In the Java perpsective from the C in the toolbar with the drop down
list select Visual Class, or use File=>New=>Visual Class. This creates a
regular .java file except that the Visual Editor is used which is 1/2 visual
at the top and 1/2 embedded Java at the bottom. There are some viewlet demos
at http://www.eclipse.org/vep/ and follow the link to Documents. Having
closed a file down to re-open it just double click it(Eclipse remembers the
last editor used as the default) or else use Open With=>Visual Editor from
the pop-up.
Joe
Re: How to launch Visual Ediitor [message #574475 is a reply to message #10993] Mon, 15 December 2003 18:07 Go to previous message
Hi Hans,
> none.
the pop-up.
Joe
Previous Topic:How to launch Visual Ediitor
Next Topic:VE does not install
Current Time: Wed Apr 16 11:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
