Home » Eclipse Projects » GEF » refreshChildren
| refreshChildren [message #120251] |
Wed, 03 March 2004 06:03  |
Originally posted by: bbdaffy.hotmail.com
Using LogicDnd example as a reference, I wrote a plugin which is somewhat
similar. I have a TreeViewer of objects from which I can drag the object
onto a graphical editor and it will appear in the editor as a UML Class
Figure. I used the standard DragSupport in the TreeViewer and a
AbstractTransferDropTargetListener in the editor. All works well and the
new object gets added as a child to the container which I am editing.
However, although the Model (MVC paradigm) gets updated, and the update is
propagated to the EditPart via PropertyChangeListener, the View does not
get updated instantly. I need to either switch to another view and back,
or minimise the workbench and then restore it, in other words, I have to
somehow force the editor to refresh itself. I know something is wrong with
my code somewhere but I am not sure where to look. I tried using a
refreshVisual() after I called refreshChildren(), but it din work. Please
help. Thanks.
Rgds,
Lee
| Re: refreshChildren [message #120348 is a reply to message #120251] |
Wed, 03 March 2004 10:06   |
If you drag another window across your diagram, does it repaint the newly
created object?
"Lee" <bbdaffy@hotmail.com> wrote in message
news:c24e2d$d6m$1@eclipse.org...
> help. Thanks.
> Rgds,
> Lee
| Re: refreshChildren [message #120435 is a reply to message #120348] |
Wed, 03 March 2004 19:59   |
Yes...
Rgds,
Lee
> created object?
> > Hi,
> > help. Thanks.
> > Rgds,
> > Lee
| Re: refreshChildren [message #121752 is a reply to message #120435] |
Wed, 10 March 2004 20:08   |
Errr, can someone please further enlighten me on this issue? Thanks....
Rgds,
Lee
Lee wrote:
> Yes...
> Rgds,
> Lee
> > created object?
> > > Hi,
is
with
> > > help. Thanks.
> > > Rgds,
> > > Lee
| Re: refreshChildren [message #121765 is a reply to message #121752] |
Wed, 10 March 2004 22:25   |
Post a code snippet showing the problem.
news:c2oe5n$ejc$1@eclipse.org...
> Rgds,
> Lee
> Lee wrote:
> > Yes...
> > Rgds,
> > Lee
newly
> > > created object?
> > > > Hi,
somewhat
object
Class
the
editing.
update
> is
not
back,
have to
wrong
> with
Please
> > > > help. Thanks.
> > > > Rgds,
> > > > Lee
| Re: refreshChildren [message #121962 is a reply to message #121765] |
Fri, 12 March 2004 01:36   |
I totally have no clue where the problem could be. And I dun think I can
possibly post the entire plugin here. So I just post a few snippets,
hopefully it shows the problem....
If my children has been changed, I will fire an event...
public void addModel(Model mod) {
this.models.add(mod);
fireStructureChange(CHILDREN, mod);
This will be captured by the following method in the EditPart.
public void propertyChange(PropertyChangeEvent arg0) {
// TODO Auto-generated method stub
String propName = arg0.getPropertyName();
if(Entity.CHILDREN.equals(propName))
refresh();
else
System.err.println(this.getClass().getName() + ".propertyChange unknown
propName: " + propName);
Is there anything else I need to post to be helpful? Thanks...
Rgds,
Lee
> > Rgds,
> > Lee
> > Lee wrote:
> > > Yes...
> > > Rgds,
> > > Lee
> newly
> > > > created object?
> > > > > Hi,
> somewhat
> object
> Class
> the
> editing.
> update
> > is
> not
> back,
> have to
> wrong
> > with
> Please
> > > > > help. Thanks.
> > > > > Rgds,
> > > > > Lee
| Re: refreshChildren [message #121999 is a reply to message #121962] |
Fri, 12 March 2004 10:22   |
Does the same function work in the Logic example? BTW, you can drag and
drop items form the logic palette into the diagram.
I would suggest putting breakpoints in things that you expect to be
happening. Such as Figure.repaint(), DeferredUpdateManager.repairDamage(),
etc.
news:c2rlq1$4u1$1@eclipse.org...
> refresh();
> else
> Rgds,
> Lee
Thanks....
> > > Rgds,
> > > Lee
> > > Lee wrote:
> > > > Yes...
> > > > Rgds,
> > > > Lee
the
> > newly
> > > > > created object?
> > > > > > Hi,
> > somewhat
the
> > object
UML
> > Class
and
> > the
> > editing.
> > update
> > > is
does
> > not
and
> > back,
> > have to
> > wrong
> > > with
a
work.
> > Please
> > > > > > help. Thanks.
> > > > > > Rgds,
> > > > > > Lee
| Re: refreshChildren [message #122238 is a reply to message #121999] |
Mon, 15 March 2004 00:40  |
Thanks. I will try doing that first to narrow down my area for debugging.
Rgds,
Lee
> etc.
> > Hi,
> > refresh();
> > else
> > Rgds,
> > Lee
> Thanks....
> > > > Rgds,
> > > > Lee
> > > > Lee wrote:
> > > > > Yes...
> > > > > Rgds,
> > > > > Lee
> the
> > > newly
> > > > > > created object?
> > > > > > > Hi,
> > > somewhat
> the
> > > object
> UML
> > > Class
> and
> > > the
> > > editing.
> > > update
> > > > is
> does
> > > not
> and
> > > back,
> > > have to
> > > wrong
> > > > with
> a
> work.
> > > Please
> > > > > > > help. Thanks.
> > > > > > > Rgds,
> > > > > > > Lee
Current Time: Sat Nov 01 13:39:40 EDT 2025
Powered by FUDForum. Page generated in 0.06072 seconds
